This seems overly complex to me.
But besides that, your error is you have to pass your Queues to the Procedure as arguments. Global vals and vars cannot see each other.
Another problem is this approach has a high probability of causing your Rules to come to a halt. There are only five Rules execution threads available to you. If for some reason telegram goes down for more than five minutes then you will have five copies of “ResendAllTelegrams” running at the same time and no other rules will be able to run until telegram comes back and one of those five rules finishes sending the missed telegrams and exits.
A third problem is the ResendAllTelegrams will furiously try to resend the messages as fast as it possibly can (times 5). I suspect eventually Telegram will ban your IP or your API key for spamming the system with requests.
I would use Timers instead of a Queue to resend the messages:
import java.util.Map
val Map<String, Timer> timers = createHashMap
val Procedures.Procedure3<String, String, Map<String, Timer>> fnSendTelegram = [ Bot, Message, timers |
val success = sendTelegram(Bot, Message)
if(success) return;
val key = now.toString
timers.put(key, createTimer(now.plusMinutes(1), [ |
val success = sendTelegram(Bot, Message + "\r\nErster Versuch: " + key)
if(!success) timers.get(key).reschedule(now.plusMinutes(1))
else timers.put(key, null)
rule "Clear missed messages"
// some Item received a command
timers.values.cancel
timers.clear
In the above approach, on a failure, each message gets its own timer that retries sending that message every minute. I added a new rule to clear out the missed messages should you ever need to.
Another approach can use a single Timer in place of the Rule you currently have to avoid the running out of execution threads problem.
import java.util.List
val List<List<String>> missedMessages = new ArrayList<List<String>>()
val Procedures.Proicedure3<String, String, List<List<String>> fnSendTelegram = [ Bot, Message, missed |
if(success) return;
val List<String> msg = createArrayList
msg.add(Message)
msg.add(Bot)
msg.add(now.toString)
// timer is running if missed has elements
if(missed.size > 0) missed.add(msg)
// create the timer to catch up with the missed elements
else {
while(missed.size > 0){
missed.forEach[ List<String> msg |
val suc = sendTelegram(msg.get(0), msg.get(1) + "\r\nErster Versuch: " + msg.get(2))
if(suc) missed.remove(msg)
Thread::sleep(1000) // avoid spamming Telegram service
Thread::sleep(60000)
missedMessages.clear
The code isn’t quite as clean as the separate Timers for each message but this has the advantage that the messages will be resent in their original order (more or less, if the telegram service comes back online in the middle of executing the forEach loop then the messages will be sent out of order). The way it works is if the message fails it looks to see if there have already been failed messages. If there have it adds this message to the list. If not then it creates a Timer that tries to send the messages again every minute.
I personally like the first approach much better but you might want to preserve the order which would require the second approach.
If you absolutely must have the messages sent in order it gets a little more complex:
if(success) return;
msg.add(Message)
msg.add(Bot)
else {
var cont = true
while(missed.size > 0 && continue){
val msg = missed.size.get(0)
cont = sendTelegram(msg.get(0), msg.get(1) + "\r\nErster Versuch: " + msg.get(2))
if(cont) {
missed.remove(0)
Thread::sleep(1000)
In the above, we immediately stop trying to send messages in the Timer when one message fails and wait another minute before trying again. This will avoid trying to send subsequent messages we know will fail and it lets us preserve the original order of the messages.
NOTE: All of these approaches are just typed in. There are likely typos.
