Sharpy
(Aaron Sharp)
November 23, 2017, 9:01pm
1
Are Philips hue and freinds compatible out of the box if you the hub and installed binding (Using PaperUI)
I read something about the bindings being old and you need to manually create sitemaps ect (I have no experience doing text edits)
If there is better solutions than hue please let me know
sihui
(SiHui)
November 25, 2017, 5:28pm
2
I cannot find anything about that in the docs, so your source must have been wrong or old.
But you have to define the things file manually because of the generated user name. But that can also be found in the docs.
http://docs.openhab.org/addons/bindings/hue/readme.html#thing-configuration
Sharpy
(Aaron Sharp)
December 5, 2017, 9:36pm
3
I have just added a hue Bridge and two bulbs just white bulbs at the moment binding worked perfect
Thanks for the help appreciate that
Sharpy
(Aaron Sharp)
December 8, 2017, 8:06pm
4
Is the hue motion sensor supoorted with the hue binding I couldent see it under supported devices
cweitkamp
(Christoph Weitkamp)
December 8, 2017, 9:47pm
5
I am afraid the answer is: No. But you can have a look here Philips HUE Motion sensor in OH2? how to integrate the motion sensor with HTTP binding and JS transformation.
Sharpy
(Aaron Sharp)
December 9, 2017, 8:26pm
6
That’s a shame I would have thought it was supported just not listed I’m not sure about setting up the http part and I don’t own a hue sensor
Do you know if there are plans on adding it to the binding
cweitkamp
December 10, 2017, 9:22pm
7
Of course we want to have it in the binding. If anyone has time to implement it, please do so and contribute.
This issue is cloned from openhab/openhab2-addons#1260 since Hue Binding is maintained in eclipse/smarthome repository.
Original issue description by @regnets
I purchased a Philips...
Binding-Hue
enhancement
help wanted
Sharpy
(Aaron Sharp)
December 11, 2017, 10:33am
8
i have time not the skill
