A simple list-item widget (for use in location-pages) which enables control of a raffstore including slat-angle controls selectable via buttons.
Changelog
Version 1.0
- initial release
Usage
To make this widget work, you will need the following item structure
X_Raffstore:Rollershutteritem used as the main control; must acceptUP,DOWN,STOP, and0–100percent commands and report a numeric position state.X_Raffstore_Position:Numberitem providing position feedback in the0–100range; used only for displaying the percentage text (shows—if missing orNULL).X_Raffstore_TargetSlat:Numberitem that receives slat target commands0,25,50,75, and100(mapped to discrete slat angles from fully open to fully closed); must be handled by rules or a binding.X_Raffstore_Slat:Numberitem reporting the current slat position in the0–100range; the widget rounds this to the nearest 25 to highlight the active angle button.- Naming constraint:
props.itemmust end in_Raffstore; all other items are derived from this base name and must exist with exactly these suffixes for full functionality.
Resources
Version 1.0
YAML Code
uid: raffstore_controller_v7
tags: []
props:
parameters:
- label: Title
required: false
type: TEXT
- description: Proxy rollershutter item, e.g. <RoomName>_Raffstore
label: Raffstore Proxy Item
required: true
type: TEXT
context: item
timestamp: Dec 22, 2025, 11:39:36 AM
component: f7-list-item
class: media-item
slots:
default:
- component: oh-rollershutter-item
after: "=(items[props.item.replace('_Raffstore','') + '_Raffstore_Position'] &&
'_Raffstore_Position'].state !== null) ? ('' +
'_Raffstore_Position'].state + '%') : '—'"
icon: blinds
iconUseState: true
item: =props.item
stylesheet: |
.item-after { float: right; }
title: "=props.title ? props.title : props.item"
- component: f7-block
style:
margin-top: 10px
slots:
default:
- component: f7-segmented
slots:
default:
- component: oh-button
action: command
actionCommand: "0"
actionItem: =props.item.replace('_Raffstore','') + '_Raffstore_TargetSlat'
class: "=(Math.round(Number(items[props.item.replace('_Raffstore','') +
'_Raffstore_Slat']?.state || 0)/25)*25 === 0) ?
'button-active' : ''"
outline: true
round: true
text: 0°
action: command
actionCommand: "25"
'_Raffstore_Slat']?.state || 0)/25)*25 === 25) ?
outline: true
round: true
text: 45°
action: command
actionCommand: "50"
'_Raffstore_Slat']?.state || 0)/25)*25 === 50) ?
outline: true
round: true
text: 90°
action: command
actionCommand: "75"
'_Raffstore_Slat']?.state || 0)/25)*25 === 75) ?
outline: true
round: true
text: 135°
action: command
actionCommand: "100"
'_Raffstore_Slat']?.state || 0)/25)*25 === 100) ?
outline: true
round: true
text: 180°
