sberer
(Stephan Berer)
October 23, 2018, 4:12am
1
What thing / binding would you recommend to track the quantity of rainfall?
Vradatta
(Eric Zenz-Matzl)
October 23, 2018, 5:48am
2
I only know two solutions (don’t DIY)
One Z-Wave Rain Sensor (Popp Z-Rain )
And one from Homematiic (Homematic IP Weatherstation Plus )
I have the Z-Rain Sensor but i haven’t tested it with openhab (should work).
If you want to build one by your self, there are some guides in the Internet with arduino (https://www.mysensors.org/build/rain )
I hope this will help you.
sihui
(SiHui)
October 23, 2018, 5:52am
3
It’s also worth reading this:
Dear wonderous community,
Item 1) Merry Christmas!
Item 2) Well done and kudos on releasing 2.2! What a milestone guys!
Item 3) General thanks for this community, which is sole responsible for LEGIO hours and a few “just a second, honey” based arguments.
…and finally;
Item 4, a.k.a. The Main Topic:
I have an over complicated and ever growing ecosystem of devices running most protocols in my Swedish home. What I am struggling with is finding a good and reliable way of detecti…
Vradatta:
Z-Wave Rain Sensor
I have a Popp Z-Rain device and several questions:
The measurements are updated every approx. 4 minutes if there is a change. This is as described in the manual.
I would like to get an immediate notification/update when it starts to rain (open windows…) and not have to wait up to 4 minutes. This seems to be possible via association groups, but I don’t know how to use them. Should I add the main controller to the association group 2? How can I get an item updated from there so I can use …
rlkoshak
(Rich Koshak)
October 23, 2018, 6:32pm
4
I’ve thinking about building a weather station at some point. I’m probably going to go DIY but based on my research for rain sensing you need two sensors.
The seesaw type sensor will tell you how much rain you have received. But you need something like https://www.gearbest.com/other-accessories/pp_1802002.html?wid=1433363¤cy=USD&vip=4444999&gclid=Cj0KCQjwjbveBRDVARIsAKxH7vnnhwkWFcxNKl_mif7aRgwSYt-M7KFS-AHThmx0IDQND8HE7MV10OEaAvL8EALw_wcB to detect when the rain starts and stops immediately.
Good luck!
