I wanted to put out our Christmas lights yesterday, but the control (old light organ) isn’t alive anymore…
So I need a fast alternative, and bought myself 6 zwave outputs (3x Fibaro Double Switch 2).
I now want to create a group AS of 4 outputs, and a group AF of 2 outputs. The group AS is simply different lights over the house (fe gutter, trees, bush…), the AF are 2 light strings in 1 tree (so a flip-flop).
What I was thinking of:
- AS should go slowly (fe 60 sec) from one to the other, and AF should go fast (fe 5 sec).
- Would be great if all things are radomly, and sometimes 1, sometimes 2, sometimes 3 outputs…
- Maybe even the AS timing could be random
Fe between fe 30sec and 180sec? - And it would be really great the AF group, is used inside the AS group
So instead of 4, we would have 5 outputs (4 real ones, and 1 dummy (existing of 2 real one)). - And like a good house-father, these lights should only switch on with sunset till fe midnight.
Any idea/suggestions/examples of a rule?
