Under advanced there is a reset gateway. Wonder if that resets it?
There must be output of the command
which is written to /tmp directory into the file list-of-installed-packages.txt
So far I thought that the pairing details are stored in the Raspbee itself but it looks like data is stored in /root/.local/share/dresden-elektronik/deCONZ/ . It should be possible to copy these settings to the new instance.
You first may test the reset of the gateway as described by Danny.
Denbian version:
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Hello All,
I have a Raspberry Pi 4B, openHabian and Raspbee2.
deconz is installed and running:
[00:05:01] openhabian@openhab:/tmp$ systemctl list-unit-files |grep -i deconz
deconz-gui.service disabled
deconz-homebridge-install.service disabled
deconz-homebridge.service disabled
deconz-init.service disabled
deconz-update.service enabled
deconz-wifi.service enabled
deconz.service enabled
Phoscon App (connected via web on the port 80) shows Firmware not connected.
I added to the /etc/default/openhab2
EXTRA_JAVA_OPTS="-Xms192m -Xmx320m -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0"
But nothing change on the Phoscon App.
I tried to change /boot/config.txt by adding a last line with
enable_uart=1
and after the reboot, I am not able to coonect via SSH or to the web interface via port 8080.
I tried to reinstall everthing several time, but I do not know how to debug it further.
Would you have advise to share?
Did you follow instructions to enable serial port in openhabian config?
Also deconz instructions for serial port?
I did not need to add all the serial port info to java options for my conbee.
did you follow step 6 ( RaspBee Installation ) as you are on Pi 4B ?
any entry in output of command dmesg after boot that shows that the device is detected ?
First of all, thanks for your sharing!
I looked for several posts, comments, instructions on the web. However, I think that due to my inexperience, it was not clear to me what to do. So, I tried to follow the instructions based on my interpretation with the aim to solve the issue and aquire knwohow.
However, let me summurize what I finally did and its result.
ensured that the user openHAB is in the group
dialout
, It was the case since the installation -
in the openhabian-config, I disable the bluetooth. After this step, I had to remove the raspbee2 from the pi (this is most recent update) otherwise the OH is not accessible via putty or on the port 8080.
in the openhabian-config, I disable the serialport. After this step I tried to replug the raspbee into the board and the OH worked.
commands proposed in this post few lines above (with sudo apt upgrade, after the update)
- as suggested, I did the following step:
- in the /lib/systemd/system/deconz.service change the port to 8090 instead of 80
With these steps, it works!
My guess is that the proposer order of actions and/or the variant on my step 3 are the key of success. Thanks for your kind support.
