HoPi
(Dennis)
July 13, 2016, 1:32pm
#1
Hi there,
about half a year ago, I got OpenHAB (IIRC 1.6.x) running on a RaspberryPi. Now, I tried to install the latest version on a new Raspberry.
I’m following this document: http://docs.openhab.org/installation/apt.html
This is what happens (I had to mask the links because of forum restrictions):
pi@raspberrypi:~ $ wget -qO - ‘h__ps:–bintray.com/user/downloadSubjectPublicKey?username=openhab’ | sudo apt-key add -
OK
pi@raspberrypi:~ $ echo ‘deb h__p:–dl.bintray.com/openhab/apt-repo2 stable main’ | sudo tee /etc/apt/sources.list.d/openhab.list
pi@raspberrypi:~ $ sudo apt-get update
OK h__p:–ppa.launchpad.net precise InRelease
OK h__p:–archive.raspberrypi.org jessie InRelease
OK h__p:–mirrordirector.raspbian.org jessie InRelease
Ign h__p:–dl.bintray.com stable InRelease
Ign h__p:–dl.bintray.com stable Release.gpg
OK h__p:–ppa.launchpad.net precise/main armhf Packages
OK h__p:–ppa.launchpad.net precise/main Translation-en
OK h__p:–archive.raspberrypi.org jessie/main armhf Packages
OK h__p:–archive.raspberrypi.org jessie/ui armhf Packages
OK h__p:–mirrordirector.raspbian.org jessie/main armhf Packages
OK h__p:–archive.raspberrypi.org jessie/staging armhf Packages
OK h__p:–mirrordirector.raspbian.org jessie/contrib armhf Packages
OK h__p:–mirrordirector.raspbian.org jessie/non-free armhf Packages
OK h__p:–mirrordirector.raspbian.org jessie/rpi armhf Packages
Fehl h__p:–dl.bintray.com stable/main armhf Packages
404 Not Found [IP: 159.122.18.156 80]
Ign h__p:–dl.bintray.com stable/main Translation-de_DE
Ign h__p:–dl.bintray.com stable/main Translation-en
Ign h__p:–archive.raspberrypi.org jessie/main Translation-de_DE
Ign h__p:–archive.raspberrypi.org jessie/main Translation-en
Ign h__p:–archive.raspberrypi.org jessie/staging Translation-de_DE
Ign h__p:–archive.raspberrypi.org jessie/staging Translation-en
Ign h__p:–archive.raspberrypi.org jessie/ui Translation-de_DE
Ign h__p:–archive.raspberrypi.org jessie/ui Translation-en
Ign h__p:–mirrordirector.raspbian.org jessie/contrib Translation-de_DE
Ign h__p:–mirrordirector.raspbian.org jessie/contrib Translation-en
Ign h__p:–mirrordirector.raspbian.org jessie/main Translation-de_DE
Ign h__p:–mirrordirector.raspbian.org jessie/main Translation-en
Ign h__p:–mirrordirector.raspbian.org jessie/non-free Translation-de_DE
Ign h__p:–mirrordirector.raspbian.org jessie/non-free Translation-en
Ign h__p:–mirrordirector.raspbian.org jessie/rpi Translation-de_DE
Ign h__p:–mirrordirector.raspbian.org jessie/rpi Translation-en
W: Fehlschlag beim Holen von h__p:–dl.bintray.com/openhab/apt-repo2/dists/stable/main/binary-armhf/Packages 404 Not Found [IP: 159.122.18.156 80]
E: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
The Raspberry is running NOOBS v1.8. Any suggestions?
Thanks in advance!
Have you changed by any means speach and/or keyboard settings from the original to another language or country?
Cheers
Björn
HoPi
(Dennis)
July 14, 2016, 6:04am
#3
I might have changed the locale settings to Germany while initially setting up, or they were being set automatically. Is there anything you want me to check for in specific?
Has happend also to me.
It took me ages to find out:
Somehow the settings to German language as well as keyboard layout somehow are in contradiction with what the Raspi need to carry out the updates.
I started from scratch but maybe a solution is to change back to the original settings.
Maybe this helps.
Cheers
sihui
(SiHui)
July 20, 2016, 9:45am
#5
There is no folder “stable”, therefore you get a 404 not found error, take a look here:
http://dl.bintray.com/openhab/apt-repo2/dists/
Maybe this discussion gets you on the right track:
theo:
I'll try to clarify things: According to my understanding the first stable release will be 2.0.0 - without any beta in the version number. Any beta release is a "testing" release. Therefore currently no packages for "stable" are available. As long as only beta releases are available use: deb http://dl.bintray.com/openhab/apt-repo2 testing main There are further expert options: If you want to stick with a specific openHAB version and prevent automatic updates as soon as apt-get update && ap…
