Raspberry Pi 5 GPIO access (pigpio binding)
Platform information:
Hardware: Raspberry Pi 5
Issue of the topic: pigpio does not support RPi5
Hi all, I just upgraded my hardware from a RPI4 to a RPi5 and realized that pigpio does not work on the latter, see also Github.
To be able to access the GPIOs with my Openhab installation, i created a docker container running mqtt-io incombination with gpiozero as a workaround. With the container running you can access the RPi5 GPIOs via MQTT.
I uploaded the corresponding code and some brief instructions to github.
https://github.com/Radioaktivman/rpi5-mqtt-io-bridge/
Please feel free to use the workaround, in case you come accross the same issue.
Thanks for the post! This is one of those rare cases where I needed to move a post into the Tutorials and Solutions category. It is more clear that you’ve posted a workaround (or for some perhaps a permanent approach to control GPIO on machines other than the same one where OH is running.
Hello radioaktivman,
I have openhab4 instance on my Raspberry Pi 4 and it works perfectly. So when PI5 has arrived on the market I decided to upgrade it and as you guess this it the reason I’m in this thread :wink:
pigpio is not developed anymore and does not work on PI5 nowadays.
I was trying to run this container on my PI5 and it finishes with these errors below. I have a quite good knowledge of Linux but I’m totally green in Python so I don’t know how to deal with it. Maybe I’m doing something wrong…
2024-05-15 10:55:50 mqtt_io.__main__ [ERROR] MqttIo crashed!
Traceback (most recent call last):
  File "/usr/local/lib/python3.8/site-packages/mqtt_io/__main__.py", line 107, in main
    mqtt_gpio.run()
  File "/usr/local/lib/python3.8/site-packages/mqtt_io/server.py", line 1447, in run
    self._init_gpio_modules()
  File "/usr/local/lib/python3.8/site-packages/mqtt_io/server.py", line 273, in _init_gpio_modules
    self.gpio_modules[gpio_config["name"]] = _init_module(
  File "/usr/local/lib/python3.8/site-packages/mqtt_io/server.py", line 131, in _init_module
    return module_class(module_config)
  File "/usr/local/lib/python3.8/site-packages/mqtt_io/modules/gpio/__init__.py", line 106, in __init__
    self.setup_module()
  File "/usr/local/lib/python3.8/site-packages/mqtt_io/modules/gpio/gpiod.py", line 35, in setup_module
    self.chip = gpiod.chip(self.config["chip"])
  File "/usr/local/lib/python3.8/site-packages/gpiod/libgpiodcxx/__init__.py", line 105, in __init__
    self.open(device, how)
  File "/usr/local/lib/python3.8/site-packages/gpiod/libgpiodcxx/__init__.py", line 132, in open
    chip_struct = func(device)
  File "/usr/local/lib/python3.8/site-packages/gpiod/libgpiod/__init__.py", line 1098, in gpiod_chip_open_lookup
    chip = gpiod_chip_open_by_label(descr)
  File "/usr/local/lib/python3.8/site-packages/gpiod/libgpiod/__init__.py", line 1065, in gpiod_chip_open_by_label
    chip_iter = iter(gpiod_chip_iter())
TypeError: iter() returned non-iterator of type 'NoneType'
  File "/usr/local/lib/python3.8/runpy.py", line 194, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/local/lib/python3.8/runpy.py", line 87, in _run_code
    exec(code, run_globals)
  File "/usr/local/lib/python3.8/site-packages/mqtt_io/__main__.py", line 115, in <module>
    main()
    mqtt_gpio.run()
    self.setup_module()
Config is modified:
mqtt:
  host: localhost
  topic_prefix: home
gpio_modules:
  - module: gpiod
    chip: gpiochip4
digital_outputs:
  # Pin 1 is an output connected to a light
  - name: GPIO21OUT
    module: rpi
    pin: 21
    inverted: TRUE
  - name: GPIO20OUT
    module: rpi
    pin: 20
    inverted: TRUE
  - name: GPIO16OUT
    module: rpi
    pin: 16
    inverted: TRUE
  - name: GPIO12OUT
    module: rpi
    pin: 12
    inverted: TRUE
As you see a part of it is from your example, because I even cannot run this container so I still haven’t it adapted for my needs.
I am very sorry for the long delay.
Somehow, I did miss the notification informing me about your post.
The docker container is still running with any issue. Given the information provided, i can only speculate that it may be a rights issue. Does the docker user has right to access /dev/gpiochip4?
I think in older versions of Raspberry Pi OS used /dev/gpiochip4 but at some point I had to update to /dev/gpiochip0 (on an RPi 5)
Also depending on the environment that the python script is running in, the chip may need to be referenced as /dev/gpiochip0 in full rather than gpiochip0
I use gpiod (a wrapper of the libgpiod library) but in a separate script rather than a binding.
It would be great if someone could test this
