I have upgraded my raspberry pi installation today.
Since this, openhab doesn’t start.
Here is my syslog error :
Dec 27 12:53:50 raspberrypi start.sh[5529]: Launching the openHAB runtime…
Dec 27 12:53:52 raspberrypi start.sh[5529]: Unknown constant tag 118 in class file java/util/regex/Pattern
Dec 27 12:53:52 raspberrypi start.sh[5529]: Error occurred shutting down framework: java.lang.ClassFormatError: java/util/regex/Pattern
Dec 27 12:53:52 raspberrypi start.sh[5529]: java.lang.ClassFormatError: java/util/regex/Pattern
Dec 27 12:53:52 raspberrypi start.sh[5529]: at java.lang.String.replaceAll(String.java:2223)
Dec 27 12:53:52 raspberrypi start.sh[5529]: at org.apache.felix.utils.properties.InterpolationHelper.unescape(InterpolationHelper.java:400)
Dec 27 12:53:52 raspberrypi start.sh[5529]: at org.apache.felix.utils.properties.InterpolationHelper.substVars(InterpolationHelper.java:235)
Dec 27 12:53:52 raspberrypi start.sh[5529]: at org.apache.felix.utils.properties.InterpolationHelper.substVars(InterpolationHelper.java:198)
Dec 27 12:53:52 raspberrypi start.sh[5529]: at org.apache.felix.utils.properties.InterpolationHelper.substVars(InterpolationHelper.java:132)
Dec 27 12:53:52 raspberrypi start.sh[5529]: at org.apache.karaf.util.config.PropertiesLoader.loadSystemProperties(PropertiesLoader.java:120)
Dec 27 12:53:52 raspberrypi start.sh[5529]: at org.apache.karaf.main.ConfigProperties.(ConfigProperties.java:203)
Dec 27 12:53:52 raspberrypi start.sh[5529]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:226)
Dec 27 12:53:52 raspberrypi start.sh[5529]: at org.apache.karaf.main.Main.main(Main.java:191)
Dec 27 12:53:52 raspberrypi systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
Dec 27 12:53:52 raspberrypi stop[5689]: stop: Ignoring predefined value for KARAF_HOME
Has someone a solution ?
It s a test environment without much installed on it.
