But my system is not stable. Intermittently I lose the interface on eth0 and can no longer reach host, not even ping it. The system seems to continue to run (login with monitor HDMI and USB keyboard is possible) but I canât see what is causing the problem. I suspect a memory problem. I can pretty much rule out hardware problems or corrupt SD cards. Iâm not a Linux expert. Can it be that the large memory space of ZRAM causes the problem?
This is what I checked before opening this topic. I hat a lot of hardware checks in the last weeks (RasPi, Power supply, SD card). I can pretty much rule out hardware problems.
But what about ZRAM, which uses most of the ram space?
openHAB is not the only service running on my system, but evrything is running stable if openhab service is down.
I only can say, that I never had unstable effects in a similar configuration with openhab2 and no ZRAM.
With ZRAM I cannot help, though. I donât use it and have no experience with that.
As you are using openHABian it may help to add a tag the topic accordingly. That may attract other users with appropriate background.
Zram isnât free. It takes a chunk out of memory and there really is almost no memory to spare when running openHABian on an RPi 3. Assuming you really have eliminated hardware and you have deviated from stock openHABian by installing additional services it is likely that you are running out of memory and the machine is just barely able to limp along using swap because itâs run out of memory.
Though, as @stefan.oh hit upon, this sort of behavior is the stereotypical behavior when one has an insufficient power supply on an RPi. You donât say how youâve eliminated that as a problem but the symptoms scream a power supply problem.
You probably wonât get much more than this for help though. When you deviate from openHABian by, for example, installing additional services outside of openhabian-config, as you indicate youâve done, it significantly limits our ability to help. We donât know what youâve done and we donât know how youâve done it and itâs pretty much impossible to remotely debug such a setup. Thatâs why the docs warn against doing so so strongly.
*What you must not do, though, is to mess with the system, OS packages and config and expect anyone to help you with that. Letâs clearly state this as well: when you deliberately decide to make manual changes to the OS software packages and configuration (i.e. outside of openhabian-config), you will be on your own. Your setup is untested, and no-one but you knows about your changes. openHABian maintainers are really committed to providing you with a fine user experience, but this takes enormous efforts in testing and is only possible with a fixed set of hardware. You donât get to see this as a user.
So if you choose to deviate from the standard openHABian installation and run into problems thereafter, donât be unfair: donât waste maintainerâs or anyoneâs time by asking for help or information on your issues on the forum. Thank you !*
ZRAM is being used to not have to many write cycles to your SD card. It is something like a buffer to keep data in memory and reduce number of write cycles.
As you can see you have two entries zram1 and zram2. One is to âmirrorâ /var/log folder the other one for your persistence data.
I had exactly the same problem for over a year now, and only two weeks ago (after having exchanged / tried almost everything) seem to have solved it. See here for what I tried: Raspberry Pi 2 loses ethernet connection - #26 by Cplant . Let me know if this helps. Error logs would be helpful as well. Spoiler: It now only seems to run smoothly after having replaced the router (acting as an ethernet switch / probably a random incompatibility).
Thanks Rick for the clear statement. I havenât read all the docs. I understand the claim of developers to only be able to support efficiently if the scenario is comprehensible and reproducible. But itâs not that easy from my point of view. With the Exec binding, openhab provides a powerful tool that nobody would want to do without. As soon as the Binding scripts calls, a âprotectedâ environment is left.
My question is not about looking for errors in openhab, but about asking the community if anyone knows of similar effects and has already found solutions. Maybe my environment is to blame for the misbehaviour, maybe not.
My suspicion that ZRAM creates a problem has not been confirmed. I reduced the RAM space for log files. The memory utilization of the Rasp Pi looks good.
I still sometimes lose the interface in eth0.
I forgot to mention that I use habPanel. Now I have the suspicion that it could be related to the browser on my computer. Iâm using MS Edge and the loss of interface could be related to the browser automatically terminating (due to lack of traffic) and reconnecting.
Firefox has been running in this scenario for the last two days without any problems âŠ
I experienced losing connectivity with my Raspi 3b very likely due to SD corruption in the past. After a long list of attempts to improve stability, I ended up with a 4gb Raspi 4 connected to a ups (not a powerbank}.
There is a script running to read ble devices, in addition to openhab. I also use habapp.
This is very stable, for my application of course, even if after some weeks the zram directories become read-only, possibly due to some memory leak that I have not been able to find so far (the system does not report memory java heap size or disk usage as being full, though).
I would suggest that you upgrade to a raspi v4 with more memory or split the services on a second raspberry V3.
This! It still very much sounds like a hardware problem.
But you keep shooting at the dark.
Unless and until you have an error message or other proper indication what else it might be, asking us to help you with that is wasting peopleâs ressources here on everybodyâs part.
Sorry but thatâs a very inefficient approach.
So first and foremost, please reproduce your problem with a different RPi and a 2.5A or better power supply. Exchanging your SD is a good idea, too.
Does the system âreturnâ after you cannot ping it anymore ?
Does the red LED flicker at times ? Do you see âundervoltageâ messages in syslog ?
Read up on the background here.
you running Python?
just paste this in a file and run it (tested with python2):
#!/usr/bin/env python2
import subprocess
GET_THROTTLED_CMD = 'vcgencmd get_throttled'
MESSAGES = {
0: 'Under-voltage!',
1: 'ARM frequency capped!',
2: 'Currently throttled!',
3: 'Soft temperature limit active',
16: 'Under-voltage has occurred since last reboot.',
17: 'Throttling has occurred since last reboot.',
18: 'ARM frequency capped has occurred since last reboot.',
19: 'Soft temperature limit has occurred'
print("Checking for throttling issues since last reboot...")
throttled_output = subprocess.check_output(GET_THROTTLED_CMD, shell=True)
throttled_binary = bin(int(throttled_output.split('=')[1], 0))
warnings = 0
for position, message in MESSAGES.iteritems():
# Check for the binary digits to be "on" for each warning message
if len(throttled_binary) > position and throttled_binary[0 - position - 1] == '1':
print(message)
warnings += 1
if warnings == 0:
print("Looking good!")
else:
print("Houston, we may have a problem!")
otherwise just type vcgencmd get_throttled and look the output up:
11100000000000001010
|||| ||||_ under-voltage
|||| |||_ currently throttled
|||| ||_ arm frequency capped
|||| |_ soft temperature reached
||||_ under-voltage has occurred since last reboot
|||_ throttling has occurred since last reboot
||_ arm frequency capped has occurred since last reboot
|_ soft temperature reached since last reboot
hint:
0x0 means nothing wrong
0x50000 means throttled has occurred since the last reboot.
0x50005 means you are currently under-voltage and throttled.
Thanks guys for your support. The behavior remains suspect to me.
The only thing I can say for sure is that the effect hasnât happened since Iâve been using Firefox as the frontend for habPanel.
I had previously exchanged the Rasp Pi 3B+.
I hadnât seen any signs (flickering LEDs) or indications in the logs (kernel log) of problems with the power supply. I will still order and install another power supply in the coming days.
be aware: AFAIR thereâs no logging of undervoltage. Only thing is the above mentioned method. Thereâs also only some slowly blinking red LED-activity (sometimes not even that) indicating undervoltage => if youâre headless, thatâs pretty much the only way to âseeâ undervoltage.
Thereâs a symbol appearing in the upper left corner, if you plug in a monitor - thatâs mostly all.
