Raspi 4 rasbian+openhabian
Well if you can afford to use a 2nd box I’d not run the GUI on the OH machine since that can significantly impact stability and memory usage of the box OH runs on, i.e. your most critical server around (assuming you do not just “play” with Home Automation).
You could do that with openHABian as well, just install the GUI packages manually afterwards.
It has many advantages over your manual install such as ZRAM.
