Platform information:
Release = Raspbian GNU/Linux 10 (buster)
Kernel = Linux 5.4.51-v7l+
Platform = Raspberry Pi 4 Model B Rev 1.1 - 2GB
openHAB 2.5.9-1 (Release Build)
[09:47:46] openhabian@openhab:~$ java --version openjdk 11.0.8 2020-07-14 LTS OpenJDK Runtime Environment Zulu11.41+75-CA (build 11.0.8+10-LTS) OpenJDK Client VM Zulu11.41+75-CA (build 11.0.8+10-LTS, mixed mode)
I have run Option 54- Raw Copy SD several couple of times. I get the following message:
However, when I use the card, it seems to work fine. In the start logs there was only one anomaly
020-09-23 10:14:30.418 [ERROR] [me.storage.json.internal.JsonStorage] - Error reading JsonDB from /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.thing.Thing.json. Cause com.google.gson.stream.MalformedJsonException: Unterminated array at line 8347 column 10 path $.zwave:device:f55aa6d7:node43.value.channels[3].channelTypeUID.segments[2].
2020-09-23 10:14:30.422 [INFO ] [me.storage.json.internal.JsonStorage] - Json storage file at '/var/lib/openhab2/jsondb/org.eclipse.smarthome.core.thing.Thing.json' seems to be corrupt - checking for a backup.
2020-09-23 10:14:30.468 [INFO ] [me.storage.json.internal.JsonStorage] - Json storage file at '/var/lib/openhab2/jsondb/backup/1600864802678--org.eclipse.smarthome.core.thing.Thing.json' is used (backup 1).
It appears the file above changed during the copy process, probably the cause of the error, but a back-up was loaded. My question is, can the openhabian-config be run with openhab2 stopped? That might make for a cleaner copy. At the partition level everything also looks good.
