I am trying to use Razberry Z-Wave with openhab. To connect my Fibaro Z-Wave Switch I installed Z-Way. I connected the device and stopped the Z-Way service.
After this I installed the Z-Wave Binding (“org.openhab.binding.zwave-1.7.1.jar”) as well as HABmin2.
I added "-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 " to
/etc/init.d/openhab
as well as to
/OpenHAB Home/bin/openhab.sh (via the samba connection)
In my openhab.cfg I uncommented port and healtime:
# The Z-Wave controller port. Valid values are e.g. COM1 for Windows and /dev/ttyS0 or
# /dev/ttyUSB0 for Linux
zwave:port=/dev/ttyAMA0
# Z-Wave nightly heal time. This is the hour (eg 2AM) at which the automatic nightly
# network heal will be performed.
zwave:healtime=2
Also I added the user “openhab” to the dialout group:
sudo usermod -a -G dialout openhab
Still I get the following error while starting OpenHAB and can’t control my Z-Wave devices via HABmin:
015-10-25 18:33:34.968 [DEBUG] [.z.internal.ZWaveActiveBinding] - ConverterHandler not initialised. Polling disabled.
2015-10-25 18:33:34.974 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = /dev/ttyAMA0
2015-10-25 18:33:34.975 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, healtime = 2
2015-10-25 18:33:34.977 [DEBUG] [.z.internal.ZWaveActiveBinding] - Initialising zwave binding
2015-10-25 18:33:34.979 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2015-10-25 18:33:34.985 [DEBUG] [.o.b.ntp.internal.NtpActivator] - NTP binding has been started.
2015-10-25 18:33:35.140 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
2015-10-25 18:33:35.142 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. Soft reset is false.
2015-10-25 18:33:35.144 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port /dev/ttyAMA0
2015-10-25 18:33:35.158 [DEBUG] [.myopenhab.internal.MyOHClient] - Transport.EVENT_REQUEST_HEADERS
2015-10-25 18:33:35.158 [DEBUG] [.rrd4j.internal.RRD4jActivator] - RRD4j persistence bundle has been started.
2015-10-25 18:33:35.227 [DEBUG] [.p.internal.PersistenceManager] - Initializing rrd4j persistence service.
2015-10-25 18:33:35.256 [ERROR] [b.z.i.protocol.ZWaveController] - Serial Error: Port /dev/ttyAMA0 does not exist
Any suggestions how to get the error fixed?
Which openhab file is the correct one for adding "-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 "?
How can I start openhab as root user?
// Got the same error while using HABmin1
Thanks!
