Hi i wanna use this script but cant seem to get it working with your plugin
// Check some condition, for example, if the TV is not already ON
if (TV_Samsung_7_Series_55_Power.state != ON) {
// Send the command to turn the TV ON
TV_Samsung_7_Series_55_Power.sendCommand("ON")
// Send the command to change the input source to HDMI
TV_Samsung_7_Series_55_Key_Code.sendCommand("KEY_HDMI")
// Set the source name (assuming you have a valid item for this)
TV_Samsung_7_Series_55_Source_Name.sendCommand("HDMI")
Please post code in code blocks. Your post is kind of half and half, which makes it difficult to read.
This looks like parts of a DSL rule, but you don’t say what isn’t working or what error messages you get in the log. All I can say is that you’re missing sendCommand on your first two commands.
You can usually just paste the relevant parts of the log into a message (also in code fences/blocks).
2024-01-29 21:29:43.148 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID '4c45f95f99' failed: // Check some condition, for example, if the TV is not already ON
if Bedroom_TV_Power.state != ON) {
Bedroom_TV_Power.sendCommand("ON")
Bedroom_TV_Key_Code.sendCommand("KEY_HDMI")
Bedroom_TV_Source_Name.sendCommand("HDMI")
Where did you get this code? The reason I couldn’t understand what you’re trying to do is that this is only the second half of a Rules DSL rule. This is what a complete rule looks like.
rule "name of rule"
something happens
do stuff
You’ve skipped the when and then portions.
If you haven’t used Rules DSL before, I don’t recommend starting now (since it’s deprecated). You should be able to do this in a UI rule without needing to code anything. If you really want to use Rules DSL, you need to learn the syntax.
