Hi all! I propose two simple functions to save and read data to a file. I use these functions to save state of items with type string and date (RRD4j doesn’t save them). However, you can use them as you wish.
//Tested ECMAS 262 11. openHAB 4.0.2
* write data to file
* @param {String} file — full file name
* @param {String} data — data
* @param {Boolean} append — true for append. False for erase old data and write new.
const fileWrite = function(file,data,append = false) {
const FileWriter = Java.type('java.io.FileWriter');
try {
const output = new FileWriter(file,append);
output.write(data);
output.close();
} catch (e) {
console.error(e);
* read data from file
* @returns {String}
const fileRead = function(file) {
const FileReader = Java.type('java.io.FileReader');
var data = '';
try {
const input = new FileReader(file);
var char;
while((char = input.read()) !== -1) {
data += String.fromCharCode(char);
input.close();
return data;
} catch(e) {
console.error(e);
