How can I create a DateTime Item from a MQTT string channel?
I want to read a value from MQTT that is formatted in ISO 8601 format. However, it is read as string channel from the binding (mqtt-homie). Is there an elegant way (no “intermediate” items/rules) to read the string channel as DateTime item?
Configuration:
- Thing is a auto-detected Homie (MQTT) device.
- Channels are auto-detected (see below for details)
- Item configuration:
DateTime Pruefung0Nextcheck "Nächste Prüfung" (gPruefung) {channel="mqtt:homie300:mqautom:flnpodio:pruefung0#nextcheck"}
- –> Datetime item stays empty. If I configure it as string, the string contains the string exactly as it is received from mqtt which is a valid ISO 8601 formatting (
2017-12-27T00:00:00Z
):openhab> smarthome:status Pruefung0Nextcheck 2017-12-27T00:00:00Z
Thing configuration details:
openhab> smarthome:things show mqtt:homie300:mqautom:flnpodio
UID: mqtt:homie300:mqautom:flnpodio
Type: mqtt:homie300
Label: flnpodio
Status: ONLINE
Bridge: mqtt:broker:mqautom
Properties:
homieversion : 4.0.0
Configuration parameters:
removetopics : false
deviceid : flnpodio
basetopic : homie
Channels:
Label: Nächste Prüfung
Type: mqtt:homie_2Fflnpodio_2Fpruefung0_2Fnextcheck
Example MQTT messages:
homie/flnpodio/pruefung0/checkobject Kompressor D - Druckbehälter - Außen
homie/flnpodio/pruefung0/nextcheck 2017-12-27T00:00:00Z
