Read dynamic variable from oh-input in oh-repeater
How can I read the variable of oh-input located in oh-repeater?
  - component: oh-repeater
      for: repVar
      sourceType: itemsInGroup
      groupItem: =[props.grpItem]
      fragment: true
    slots:
      default:
        - component: f7-row
            style:
              order: =loop.repVar_idx
          slots:
            default:
              - component: oh-input
                  type: text
                  variable: ='myInputVariable' + loop.repVar_idx.toString()
              - component: Label
                  text: =['vars.myInputVariable' + loop.repVar_idx.toString()]
                  #returns [ "vars.myInputVariable0" ]
              - component: Label
                  text: = 'vars.myInputVariable' + [loop.repVar_idx]
                  #returns vars.myInputVariable0
              - component: Label
                  text: = vars.myInputVariable0
                  #returns the entered value (input)
              - component: oh-button
                  text: save
                  action: command
                  actionItem: =loop.repVar.name
                  actionCommand: =vars.myInputVariable0
vars is not part of a strong when referencing the input variable, it is the variable object. So, that portion of the expression must not be inside quotes. You want to access to the key in the vars object that you build from the string literal and the loop index. When you access a dynamic key name like that you put that inside [ ]. So, in this case you want:
text: =vars['myInputVariable' + loop.repVar_idx]
Short and with additional background information…
Thanks a million.
- component: f7-block
    style:
      display: flex
      flex-direction: column
  slots:
    default:
          for: rPreset
          groupItem: =[props.grpPresets]
          fragment: true
        slots:
          default:
                style:
                  display: "=(vars.modeTYPE == true) ? 'flex' : 'none'"
                placeholder: =loop.rPreset.state
                outline: true
                type: text
                variable: ='varInput' + loop.rPreset_idx
                text: ="P" + (loop.rPreset_idx + 1) + "= " + loop.rPreset.state
                style:
                  display: "=(vars.modeTYPE == NULL || vars.modeTYPE == false) ? 'flex' : 'none'"
                  order: =loop.rPreset_idx
    text: save all
    action: command
    actionItem: =loop.rPreset.name
    actionCommand: =vars['varInput' + loop.rPreset_idx]
    #how can I get access to varInput0(...to 4) from this level?
If I configurate the save-button as part of the oh-repeater, I can write each input to each preset-item.
But if I drop this button outside the oh-repeater, it’s not able to read the value.
I know, why it has no access to the value, but how can I get all (5) oh-inputs written into my 5 preset-items?
The best way to do this is to this is to run a rule from the widget and pass the input variables to the rule using the rule context property of the rule action. The rule can then process the values however you wish and send the results to any items.
It is possible to do this all within the widget system however, so the fully widget way of doing this would follow
But will be kind of ridiculous for five separate items.
