Hi everyone
It’s my first question here, so please be kind.
I want to detect if a user/human used a KNX button to switch on/off/dim a KNX light.
With OpenHAB 2.x I used a dimmer-control item for this use case. This old version of the KNX binding had the bug, that a *-control item did not respond to a read request and so I could use them without changing something on the real bus.
With the current version from OpenHAB 3.3 I have the issue that OpenHAB is responding to the KNX-bus at every KNX-button-press and will create a mess on the bus. → light is flickering because OH is fighting against the dim-actor.
If I use the normal dimmer item. I get only the state of the finished dimmed light and I cannot detect if someone pressed on/off, or used the dim function.
Any (other) idea how to solve this issue?
Thanks,
Norbert
