As I read it is possible to display a switch item as text in sitemaps, but it doesn’t work for me. My aim is to display the read-only state of an calculated variable on my sitemap.
I created a very simple test, but it doesn’t work. Do you have any idea why?
my items file:
Switch test_switch_item "Test Switch Item"
my sitemap file:
sitemap test label="Teszt"
Frame{
Text item=test_switch_item
Switch item=test_switch_item
The result is the following: http://i62.tinypic.com/2a9wm5f.png
As I expected the Text field should display On or Off value in my sitemap.
