I am already reading data from my Huawei Inverter via Modbus rtu (thanks to this turorial: Reading data from Huawei inverter SUN 2000 (3KTL-10KTL) via modbus TCP and RTU)
Now I added a new power meter (EASTRON SDM72D-M) to this Bus. I gave it slave id 2.
The Modbus registers of the power meter are documened here: https://stromzähler.eu/media/pdf/6d/02/af/SDM72DM-manual.pdf
I added these lines to my existing BridgeModbus.things file:
Bridge modbus:serial:slave200 [ port="/dev/ttyUSB0" ,id=2 , baud=9600, stopBits="1", parity="none", dataBits=8, encoding="rtu" ]{
Bridge poller slave201input [ start=30073, length=8, refresh=10000, type="input" ]{
Thing data Import_kWh [ readStart="30073", readValueType="float32" ]
Thing data Export_kWh [ readStart="30075", readValueType="float32" ]
Bridge poller slave202input [ start=31281, length=8, refresh=10000, type="input" ]{
Thing data Import_W [ readStart="31281", readValueType="float32" ]
Thing data Export_W [ readStart="31283", readValueType="float32" ]
and added this to my items file:
Number Import_kWh "Stromzähler Import [%.1f kWh]" <energy> (gSolar) { channel="modbus:data:slave200:slave201input:Import_kWh:number" }
Number Export_kWh "Stromzähler Export [%.1f kWh]" <energy> (gSolar) { channel="modbus:data:slave200:slave201input:Export_kWh:number" }
Number Import_W "Stromzähler Momentan Import [%.1f W]" <energy> (gSolar) { channel="modbus:data:slave200:slave202input:Import_W:number" }
Number Export_W "Stromzähler Momentan Export [%.1f W]" <energy> (gSolar) { channel="modbus:data:slave200:slave202input:Export_W:number" }
But openhab doesnt get the values. The 4 items have the value 0. At the PaperUI the created things are online.
Can anyone help? Thank you!
Best regards
Robbelt
