- Platform information:
- Hardware: RBPi 3
- OS: Raspbian GNU/Linux 9 (stretch)
- Java Runtime Environment:(Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
- openHAB version: openHAB 2.5.0-1
I’ve installed the ZigbeeToTasmota and I receive the messages from broket mqtt like this:
"ZigbeeReceived": {
"0x7F70": {
"Temperature": 21.32,
"Humidity": 59.58,
"PressureUnit": "hPa",
"Pressure": 1013,
"Scale": -1,
"ScaledValue": 10138,
"LinkQuality": 80
Or
"ZigbeeReceived": {
"0xB307": {
"Power": false,
"LinkQuality": 18
These messages may change and not always have the same elements.
Right now I have defined elements like:
Thing topic thpEstudio "Temperatura, humedad, presion estudio" @ "Estudio" {
Channels:
Type number : temperature "Temperatura" [ stateTopic="casa/pasillo/routerZigbee/tele/SENSOR", transformationPattern="JSONPATH:$.ZigbeeReceived.0x7F70.Temperature"]
Type number : humidity "Humedad" [ stateTopic="casa/pasillo/routerZigbee/tele/SENSOR", transformationPattern="JSONPATH:$.ZigbeeReceived.0x7F70.Humidity"]
Type number : pressure "Presión" [ stateTopic="casa/pasillo/routerZigbee/tele/SENSOR", transformationPattern="JSONPATH:$.ZigbeeReceived.0x7F70.Pressure"]
Type number : batteryLevel "Nivel bateria" [ stateTopic="casa/pasillo/routerZigbee/tele/SENSOR", transformationPattern="JSONPATH:$.ZigbeeReceived.0x7F70.Battery"]
Type number : linkQuality "Zigbee Signal Strength" [ stateTopic="casa/pasillo/routerZigbee/tele/SENSOR", transformationPattern="JSONPATH:$.ZigbeeReceived.0x7F70.LinkQuality"]
But when I receive a message from something else, warnings appear in the logs. How could I avoid it?
2020-02-08 13:41:17.076 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.ZigbeeReceived.0x7F70.Battery' in '{"ZigbeeReceived":{"0xB307":{"Power":true,"LinkQuality":0}}}'
2020-02-08 13:41:17.080 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.ZigbeeReceived.0x7F70.LinkQuality' in '{"ZigbeeReceived":{"0xB307":{"Power":true,"LinkQuality":0}}}'
2020-02-08 13:41:17.084 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.ZigbeeReceived.0x7F70.Humidity' in '{"ZigbeeReceived":{"0xB307":{"Power":true,"LinkQuality":0}}}'
2020-02-08 13:41:17.088 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.ZigbeeReceived.0x7F70.Pressure' in '{"ZigbeeReceived":{"0xB307":{"Power":true,"LinkQuality":0}}}'
2020-02-08 13:41:17.092 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.ZigbeeReceived.0x7F70.Temperature' in '{"ZigbeeReceived":{"0xB307":{"Power":true,"LinkQuality":0}}}'
