Thank you for the tutorial!
We’re considering a solar system with Huawei SUN2000 and LUNA2000 battery, and I have a couple of questions and hope to get some help here:
My supplier quote me the model SUN2000-8KTL-M1, I see there is a newer version M2/M3. Anybody know the difference?
My supplier told me the inverter comes with WiFi, so I still need to buy Huawei Smart Dongle-WLAN-FE?
I read that we can read data from Modbus, can we make changes? I’m thinking change TOU based on electricity price and weather etc.
Many thanks in advance!
I’ll try to answer some questions.
As for number 1, see here https://forum.huawei.com/enterprise/en/model-m1-oder-m2/thread/667280853836906496-667213868771979264
2. My installation came with the dongle, but I’ve read that you could possibly make it work without it as well. I don’t know. Just make sure that modbus communication is enabled (at least for the dongle is must be enabled separately)
3. I haven’t tried, but I don’t see any reason why it wouldn’t work as long as the inverter supports changing the setting. See the modbus guide for the inverter for details.
And as a side note. My ground source heat pump can directly read the inverter and adjust itself based on that. But the pump and openHAB can’t both communicate with it so I had to install modbus proxy which communicates with the inverter and then the pump and openHAB talk to the proxy. Works at least as well as openHAB directly to the inverter…
Thanks for your reply! I will check with my supplier regarding the smart dongle.
It’s smart solution with the heat pump, which brand is it? We have an old ground source heat pump with Modbus but I don’t think I can control the power consumption.
We have a Nibe S1255. It’s not that obvious in the menu, but when you dig deep enough, there are setting for connecting to solar panels/inverter in there
JavaScript addon needs to be installed also it complains a 0-1.map is missing in the transformation folder so just create a file named lie that and inside put like
Hello everyone,
I’m still having problems with stability of the Things. Is there any best practice for the Thing configuration?
This is my current setup, but some Things are regularly going offline:
Retries are helpful if you have available enough of bandwidth on the bus. In case of stick - it might be simply too busy to answer first attempt, by adding retries you make it busier. If you are near bandwidth it also means that other polls will be delayed.
Advice I got from Huawei support two years ago was quite clear - in case of failure do not retry, let usb stick get and come back with next polling cycle.
Obviously it does not make OH binding happy, because it marks poller offline and can trigger monitoring rules.
2023-11-16 17:17:03.003 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Powermeter_ValueasNumber' changed from -913 W to -868 W
2023-11-16 17:17:26.620 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=32016, length=8, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 797e936d-43fc-43fe-8cd6-29f23d1d159c]
2023-11-16 17:17:35.721 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TimestampPowermeter' changed from 2023-11-16T17:17:02.963787+0100 to 2023-11-16T17:17:35.712755+0100
2023-11-16 17:17:35.725 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Powermeter_ValueasNumber' changed from -868 W to -832 W
2023-11-16 17:17:53.573 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=32064, length=31, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 81798adb-13be-463a-addf-27f04e331467]
2023-11-16 17:18:16.051 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TimestampPowermeter' changed from 2023-11-16T17:17:35.712755+0100 to 2023-11-16T17:18:16.041686+0100
2023-11-16 17:18:16.073 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Powermeter_ValueasNumber' changed from -832 W to -861 W
2023-11-16 17:18:30.519 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=32016, length=8, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID e09473b8-d09b-4c73-9c54-e440b6a8021b]
2023-11-16 17:18:52.009 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TimestampPowermeter' changed from 2023-11-16T17:18:16.041686+0100 to 2023-11-16T17:18:51.996514+0100
2023-11-16 17:18:52.012 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Powermeter_ValueasNumber' changed from -861 W to -848 W
2023-11-16 17:18:57.504 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=32002, length=1, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 1d8715c7-6317-441c-9f46-42b9efaabd01]
2023-11-16 17:19:28.530 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TimestampPowermeter' changed from 2023-11-16T17:18:51.996514+0100 to 2023-11-16T17:19:28.520774+0100
2023-11-16 17:19:28.533 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Powermeter_ValueasNumber' changed from -848 W to -860 W
Hi @bobelhage, did you - or anyone else - eventually succeed in writing (single) registers? I’m currently at the stage you were back then, reads work great, but writes don’t so anything, although the openHAB debug log states “Succesful write”. Thanks!
Hello, does anybody try to implement this in OH4?
I’ve give it a try with the tutorial for OH3 but unfortunately that doesn’t seem to work.
I’am new to openhab and sure there will be some implementation differences between OH3 and OH4.
I have already change a Dongle parameter to Enable (unrestricted) in the Modbus-TCP configuration, so I have a connection from the openhab host to the inverter
pi@HOME:/etc/openhab/things $ telnet 192.168.1.28 502
Trying 192.168.1.28...
Connected to 192.168.1.28.
Escape character is '^]'.
2023-12-30 17:23:12.433 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=37000, length=115, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID cd56dadc-c9ec-4d9d-9f08-ea6af36eb6fb]
2023-12-30 17:23:27.824 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=37000, length=115, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 9f41974f-72c9-4623-ac31-265201100a9d]
2023-12-30 17:23:42.727 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=37000, length=115, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID bfd45434-4e27-43b5-8cbf-360b2226d157]
However the one has readStart=30073, since my poll starts from 37000. Obviously it creates an issue
CONFIGURATION_ERROR
Out-of-bounds: Poller is reading from index 37000 to 37018 (inclusive) but this thing configured to read 'uint32' starting from element 30073. Exceeds polled data bounds.
When I tried to lower ‘start’ in the poll configruration, however after that change I have SocketTimeoutException any. I’m confused about the ‘start’ configuration in the poll. In this topic it looks like people are using any random number between 30000 and 37000. What is a proper setup?
