Proper setup migh depend on inverter model/firmware. The error message you got indicates that you read to little data to map it to expected type. As far I remember you need 4 bytes for uint32 (32 bits / 8 per byte => 4 bytes => 2 data registers). Make sure you adjust also read length/end.
Overall advice from huawei support I got was to read larger blocks but less often. The timeout might be result of improper handling of errors on SDongle/inverter, generally you can then assume that configuration is invalid.
Is there any documentation to check what are the address of those registries ? Otherwise itâs a high chance that I will be reading some random data. For instance Iâm reading an address of 37002 and it gives me some value between 10,000 and 50,000. How would I know what Iâm reading?
After reading the thread again as well as âSUN2000L V200R001 MODBUS Interface Definitionsâ doc file now I get it ⊠and whatâs important I made it running.
As I have all the data, I want to visualise it. Is the energie.widget.json file shared there applicable for OH4?
I donât have much an experience with habpanel. How can I add that widget?
Each UI is a separate component, you might look at widgets shared in marketplace category as they have some examples of PV/energy widgets, but for mainui.
Ideally if you run into troubles with habpanel widget you can start new thread with more precise description of issue.
with the help of this topic I was able to integrate my Huawei inverter into OH.
In general its working fine, however I receive random timeout errors with the setup below.
Question:
Any best practice / guidance someone can share on configuring the connection / timing / retry parameter in a better way?
Thanks in advance for any help!
- SUN2000-4KTL-M1 inverter (SW: V100R001C00SPC153)
- LUNA2000 battery (SW: V100R002C00SPC119)
- Smart Dongle A-05 (SW: V100R001C00SPC125)
1 TCP thing:
thingTypeUID: modbus:tcp
configuration:
rtuEncoded: false
connectMaxTries: 3
reconnectAfterMillis: 20000
timeBetweenTransactionsMillis: 5000
port: 502
timeBetweenReconnectMillis: 10
connectTimeoutMillis: 10000
host: 192.168.58.144
afterConnectionDelayMillis: 10000
enableDiscovery: false
5 Poller things, all with the following config (of cause with different start & length):
thingTypeUID: modbus:poller
configuration:
length: 4
start: 37015
refresh: 60000
maxTries: 3
cacheMillis: 50
type: holding
10 Data things, all with the following config:
thingTypeUID: modbus:data
configuration:
readValueType: uint16
readTransform: JS:divide.js?d=10
writeTransform: default
readStart: "37004"
updateUnchangedValuesEveryMillis: 30000
writeMultipleEvenWithSingleRegisterOrCoil: false
writeMaxTries: 3
and the following error messages in:
2023-12-31 12:41:22.262 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=32080, length=2, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 99eaa83d-055d-4117-9330-8346f5404ce5]
2023-12-31 12:41:32.282 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 2 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=32080, length=2, maxTries=3]). Will try again soon. The response did not match the request. Resetting the connection. Error details: org.openhab.core.io.transport.modbus.exception.ModbusUnexpectedTransactionIdException Transaction id of request (16715) does not equal response (16714). Slave response is invalid. [operation ID 99eaa83d-055d-4117-9330-8346f5404ce5]
2023-12-31 12:42:27.269 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=37113, length=12, maxTries=3]). Will try again soon. Error was I/O error, so resetting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: SocketTimeoutException Read timed out [operation ID 142ed2b6-0263-40e4-879d-7a71fa68a91f]
I wrote some time ago about this, there is a severe bug in SDongle, it confuses requests when multiple connections are being made. Make sure you have only one tcp connection at the time!
Donât ask how I found it.
That sounds reasonable.
I only have OH connecting via modbus to the dongle and using the fusion solar app. As the app is not using modbus it will not count towards the connection limit (at least thatâs my understanding).
There is no other device / server (beside OH) that will connect to the dongle.
How can I configure my things, that they do not create multiple connections (I only have 1 tcp thing)?
Hi Matze,
would it be possible to post your full setup? Items, things etc?
I donât get it working unforunately :-/
Thanks in advance.
I can have a look later, as I have managed everything via UI I need to copy and paste this.
I tried item based configuration before an also was failing, as all things went online at the same time and to many poller sending requests. Only if I enable one thing slowly after another, it will work.
Maybe thatâs already helpful to know
Which firmware do you have? I get every Bridge and Thing online, but the Items only contains NULL values. And the log file is full of errorâŠ
Dongle firmware V100R001C00SPC125
Inverter (SUN2000-5KTL-M1) Firmware: V100R001C00SPC153
2024-02-10 09:50:09.129 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Execution of scheduled (5000ms) poll task BasicPollTask [getEndpoint=ModbusIPSlaveEndpoint [address=wechselrichter.fritz.box, port=502], request=ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=32064, length=31, maxTries=3], getResultCallback()=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@2c11578f, getFailureCallback()=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@2c11578f] failed unexpectedly. Ignoring exception, polling again according to poll interval.
java.lang.NullPointerException: Cannot invoke "java.util.Map.put(Object, Object)" because "this.global" is null
at com.oracle.truffle.js.scriptengine.GraalJSBindings.put(GraalJSBindings.java:130) ~[?:?]
at javax.script.SimpleScriptContext.setAttribute(SimpleScriptContext.java:246) ~[java.scripting:?]
at org.openhab.core.automation.module.script.ScriptTransformationService.transform(ScriptTransformationService.java:187) ~[?:?]
at org.openhab.binding.modbus.internal.SingleValueTransformation.transform(SingleValueTransformation.java:140) ~[?:?]
at org.openhab.binding.modbus.internal.CascadedValueTransformationImpl.transform(CascadedValueTransformationImpl.java:50) ~[?:?]
at org.openhab.binding.modbus.internal.ValueTransformation.transformState(ValueTransformation.java:48) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.lambda$16(ModbusDataThingHandler.java:999) ~[?:?]
at java.util.HashMap$KeySpliterator.forEachRemaining(HashMap.java:1707) ~[?:?]
at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:762) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.processUpdatedValue(ModbusDataThingHandler.java:967) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.onRegisters(ModbusDataThingHandler.java:845) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.lambda$11(ModbusDataThingHandler.java:799) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:178) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.onReadResult(ModbusDataThingHandler.java:799) ~[?:?]
at org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator.lambda$2(ModbusPollerThingHandler.java:144) ~[?:?]
at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:807) ~[?:?]
at org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator.notifyChildren(ModbusPollerThingHandler.java:142) ~[?:?]
at org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator.handleResult(ModbusPollerThingHandler.java:88) ~[?:?]
at org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator.handle(ModbusPollerThingHandler.java:105) ~[?:?]
at org.openhab.core.io.transport.modbus.internal.ModbusLibraryWrapper.invokeCallbackWithResponse(ModbusLibraryWrapper.java:332) ~[?:?]
at org.openhab.core.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.lambda$1(ModbusManagerImpl.java:216) ~[?:?]
at org.openhab.core.io.transport.modbus.internal.SimpleStopWatch.timeRunnable(SimpleStopWatch.java:152) ~[?:?]
at org.openhab.core.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:216) ~[?:?]
at org.openhab.core.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:1) ~[?:?]
at org.openhab.core.io.transport.modbus.internal.ModbusManagerImpl.executeOperation(ModbusManagerImpl.java:613) ~[?:?]
at org.openhab.core.io.transport.modbus.internal.ModbusManagerImpl$ModbusCommunicationInterfaceImpl.lambda$1(ModbusManagerImpl.java:810) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
2024-02-10 09:50:24.501 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Execution of scheduled (10000ms) poll task BasicPollTask [getEndpoint=ModbusIPSlaveEndpoint [address=wechselrichter.fritz.box, port=502], request=ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=30073, length=10, maxTries=3], getResultCallback()=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@31dc4737, getFailureCallback()=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@31dc4737] failed unexpectedly. Ignoring exception, polling again according to poll interval.
2024-02-10 09:50:40.411 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Execution of scheduled (5000ms) poll task BasicPollTask [getEndpoint=ModbusIPSlaveEndpoint [address=wechselrichter.fritz.box, port=502], request=ModbusReadRequestBlueprint [slaveId=1, functionCode=READ_MULTIPLE_REGISTERS, start=32064, length=31, maxTries=3], getResultCallback()=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@2c11578f, getFailureCallback()=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@2c11578f] failed unexpectedly. Ignoring exception, polling again according to poll interval.
Dongle (SDongleA-05) V100R001C00SPC133
Inverter (SUN2000-5KTL-M1) V100R001C00SPC153
works for me
What I read from the error message is, that your script transformation is not working correctly.
Try without transformation first to validate, if the binding is working and you see the raw data.
Sorry, it took a while.
But thatâs my config:
TCP thing
UID: modbus:tcp:PV_TCP
label: PV Anlage - Modbus TCP Slave
configuration:
rtuEncoded: false
connectMaxTries: 3
reconnectAfterMillis: 10000
port: 502
host: XXX
Poller thing (active power from the meter in this case):
UID: modbus:poller:PV_TCP:PV_Poll_Meter_ActivePower
label: PV Poll Meter Active Power
configuration:
length: 12
start: 37113
refresh: 60000
maxTries: 3
cacheMillis: 50
type: holding
bridgeUID: modbus:tcp:PV_TCP
Data Thing:
UID: modbus:data:PV_Poll_Meter_ActivePower:PV_Data_Meter_ActivePower
label: PV Data Meter Active Power
configuration:
readValueType: int32
readStart: "37113"
writeMaxTries: 3
bridgeUID: modbus:poller:PV_TCP:PV_Poll_Meter_ActivePower
Item is a number item linked to the âValue as Numberâ channel with default profile.
Things I observed:
If you tested with other tools to establish a modbus connection, maybe the old connection is still open and it helps to restart the inverter.
If you mass create the things via thing file and all things go online at the same time, it did not worked for me.
I therefore created them via gui one by one.
Also after restarting OH this sometimes leads to issues and I manually need to disable all modbus things and enable them one after the other.
Hi. This thread is quite huge and I am not sure if I understood correctly.
I might be accepting an offer with an Huawei SUN2000-10KTL-M1 inverter, LUNA2000-5-S0 battery and Smart Power Sensor DTSU666-HW. But of course I only want it to get it if I am 100% sure if I can integrate it somehow into openHAB.
Could someone please confirm whether I can get current power consumption of my house, current PV gain and battery state from these components? Thanks!
I have the 8KTL-M1 and the power sensor which are working as expected on OH.
Following a screenshot showing what I have inserted in a sitemap:
I have documented the integration of my Sun2000 in OpenHAB at Huawei Sun2000 mit OpenHAB â Debacher-Wiki.
The text is in German, but if in doubt, deepl.com can help with the translation.
Thanks!
Have you attempted to force charging the battery ? Do you have any docs on how that would work ?
Hi Markus,
I have implemented it and working quite nicely with some (complex) rules. It only needs 3 or 4 Modbus registers to be written to force the charging. Will share later once Iâm back on my OH system. I âreverse-engineeredâ it from the HA implementation in GitHub (GitHub - wlcrs/huawei_solar: Home Assistant integration for Huawei Solar inverters via Modbus).
Why should I force the battery to charge?
- My inverter (Sun2000) always charges the battery (Luna2000) before it feeds into the grid.
- And charging from the grid would make no economic sense.
So I never need to force charging.
