After enabling using the command
log.set DEBUG com.zsmartsystems.zigbee
Managed to get the following command
13:23:41.066 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=39431/1, destinationAddress=0/1, profile=0104, cluster=0500, addressMode=null, radius=0, apsSecurity=false, apsCounter=00, payload=19 0E 00 11 00 00 00 00 00]
13:23:41.068 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=14, commandId=0]
13:28:22.291 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=39431/1, destinationAddress=0/1, profile=0104, cluster=0500, addressMode=null, radius=0, apsSecurity=false, apsCounter=00, payload=19 01 00 11 00 00 00 00 00]
13:28:22.293 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=1, commandId=0]
13:29:22.314 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=39431/1, destinationAddress=0/1, profile=0104, cluster=0500, addressMode=null, radius=0, apsSecurity=false, apsCounter=00, payload=19 08 00 11 00 00 00 00 00]
13:29:22.316 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=8, commandId=0]
13:29:28.679 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=39431/1, destinationAddress=0/1, profile=0104, cluster=0500, addressMode=null, radius=0, apsSecurity=false, apsCounter=00, payload=19 09 00 11 00 00 00 00 00]
13:29:28.681 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=9, commandId=0]
13:31:50.301 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=39431/1, destinationAddress=0/1, profile=0104, cluster=0500, addressMode=null, radius=0, apsSecurity=false, apsCounter=00, payload=19 0B 00 11 00 00 00 00 00]
13:31:50.302 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=11, commandId=0]
13:31:50.304 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ZoneStatusChangeNotificationCommand [IAS Zone: 39431/1 -> 0/1, cluster=0500, TID=0B, zoneStatus=17, extendedStatus=0]
15:50:01.594 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=35451/1, destinationAddress=0/1, profile=0104, cluster=0500, addressMode=null, radius=0, apsSecurity=false, apsCounter=00, payload=19 1C 00 11 00 00 FF 00 00]
15:50:01.595 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=28, commandId=0]
15:50:04.425 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=35451/1, destinationAddress=0/1, profile=0104, cluster=0500, addressMode=null, radius=0, apsSecurity=false, apsCounter=00, payload=19 1D 00 11 00 00 FF 00 00]
15:50:04.426 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=29, commandId=0]
15:50:07.031 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=35451/1, destinationAddress=0/1, profile=0104, cluster=0500, addressMode=null, radius=0, apsSecurity=false, apsCounter=00, payload=19 1E 00 11 00 00 FF 00 00]
15:50:07.033 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=30, commandId=0]
The above command showed up whenever the panic button is pressed, the question is how do I use that information and displayed it on the UI ?
