I am new on openhab and I love it despite some xxx numbers of hours trying to understand why I can’t display the Temperature of my device on my Basic UI…
I see the Information on my MQTT sent by the device.
I have tried the other method :default]" } nothing!!!
Here I’m also trying to get the Uptime of one of my Sonoff…which is the simplest thing to do. No way!
I am getting nothing on my Classic UI for example
As you can see the MQTT is working good on my RaspberryPI along with OH2.
For SoffUptime item you have to correct definition, change [%. Minutes] to [%d Hours]. I belive sonoff-tasmota is reporting uptime in hours, not minutes, unless you modified code.
Number SoffUptime "Sonoff-Uptime [%d Hours]" <clock> {mqtt.....}
Yes maybe the new update. Because everything was working before. I use wemos with bme sensors.
mqtt and all data chain was working until few weeks ago.
