I’m using the FGR222 Roller Shutter 2 to control the blinds.
Which is all working. No problems.
But, I have an issue with reading the actual “state” if the blinds are moving. I’m problably doing something wrong.
I’m sending a command with values for (0, 25, 50, 75, 100) to set the blinds in the corresponding position.
However, I would like to read the value of the current position WHILE it is moving.
This way, I can map this value against an icon, which I use in HabPanel to show the postion of the blinds…
This creates a “interactive” display of icons when lowering or pulling up the blinds.
But, I can’t seem to get the actual value from the thing, cause it seems to report the value of the thing at start and is only updated when it’s done.
Here’s the rules:
var Timer tBlind = null
rule "update Icon Value"
Item FF_Blinds_TobiasShutterPosition received command
if(tBlind === null){
logInfo("rules.blinds","tBlind is NULL")
logInfo("rules.blinds", "Initial state: " + ZWaveNode006FGR222RollerShutter2_BlindsControl.state as Number)
logInfo("rules.blinds", "Shutter position: " + FF_Blinds_TobiasShutterPosition.state as Number)
logInfo("rules.blinds", "Received command: " + receivedCommand as Number)
tBlind = createTimer(now.plusMillis(100), [|
var Number nDim = 0
var Number counter = receivedCommand as Number
var Number current = ZWaveNode006FGR222RollerShutter2_BlindsControl.state as Number
logInfo("rules.blinds", "Initial state2: " + ZWaveNode006FGR222RollerShutter2_BlindsControl.state as Number)
logInfo("rules.blinds", "Shutter position2: " + FF_Blinds_TobiasShutterPosition.state as Number)
logInfo("rules.blinds", "Received command2: " + receivedCommand as Number)
if( current != counter){
logInfo("rules.blinds", "loop Received Command: " + receivedCommand)
logInfo("rules.blinds", "loop current shutter position: " + FF_Blinds_TobiasShutterPosition.state as Number)
logInfo("rules.blinds", "loop current state as Number FF_Blinds_Tobias: " + ZWaveNode006FGR222RollerShutter2_BlindsControl.state as Number)
nDim = 200
if(nDim > 0 ){
tBlind.reschedule(now.plusMillis(nDim))
else
logDebug("rules.blinds","delete timer.")
tBlind = null
*A bit of a mess at, but I wanted to see all the different values in the different parts of the rule. *
I’m using two items…for two channels of the thing to see if there is any difference…
No, the problem is that the “state” of the blindsControl is not updated during the move of the blinds. So I can’t do anything with that value since it stays the same, until it reached the SET value…
logfile:
2019-11-17 17:55:18.057 [INFO ] [.smarthome.model.script.rules.blinds] - Initial state2: 4
2019-11-17 17:55:18.058 [INFO ] [.smarthome.model.script.rules.blinds] - Shutter position2: 77
2019-11-17 17:55:18.058 [INFO ] [.smarthome.model.script.rules.blinds] - Received command2: 77
2019-11-17 17:55:18.059 [INFO ] [.smarthome.model.script.rules.blinds] - loop Received Command: 77
2019-11-17 17:55:18.059 [INFO ] [.smarthome.model.script.rules.blinds] - loop current shutter position: 77
2019-11-17 17:55:18.060 [INFO ] [.smarthome.model.script.rules.blinds] - loop current state as Number FF_Blinds_Tobias: 4
2019-11-17 17:55:18.261 [INFO ] [.smarthome.model.script.rules.blinds] - Initial state2: 4
2019-11-17 17:55:18.262 [INFO ] [.smarthome.model.script.rules.blinds] - Shutter position2: 77
2019-11-17 17:55:18.262 [INFO ] [.smarthome.model.script.rules.blinds] - Received command2: 77
2019-11-17 17:55:18.263 [INFO ] [.smarthome.model.script.rules.blinds] - loop Received Command: 77
2019-11-17 17:55:18.263 [INFO ] [.smarthome.model.script.rules.blinds] - loop current shutter position: 77
2019-11-17 17:55:18.264 [INFO ] [.smarthome.model.script.rules.blinds] - loop current state as Number FF_Blinds_Tobias: 4
2019-11-17 17:55:18.465 [INFO ] [.smarthome.model.script.rules.blinds] - Initial state2: 4
2019-11-17 17:55:18.466 [INFO ] [.smarthome.model.script.rules.blinds] - Shutter position2: 77
2019-11-17 17:55:18.466 [INFO ] [.smarthome.model.script.rules.blinds] - Received command2: 77
2019-11-17 17:55:18.467 [INFO ] [.smarthome.model.script.rules.blinds] - loop Received Command: 77
2019-11-17 17:55:18.468 [INFO ] [.smarthome.model.script.rules.blinds] - loop current shutter position: 77
2019-11-17 17:55:18.468 [INFO ] [.smarthome.model.script.rules.blinds] - loop current state as Number FF_Blinds_Tobias: 4
2019-11-17 17:55:18.671 [INFO ] [.smarthome.model.script.rules.blinds] - Initial state2: 4
2019-11-17 17:55:18.672 [INFO ] [.smarthome.model.script.rules.blinds] - Shutter position2: 77
2019-11-17 17:55:18.672 [INFO ] [.smarthome.model.script.rules.blinds] - Received command2: 77
2019-11-17 17:55:18.673 [INFO ] [.smarthome.model.script.rules.blinds] - loop Received Command: 77
2019-11-17 17:55:18.673 [INFO ] [.smarthome.model.script.rules.blinds] - loop current shutter position: 77
2019-11-17 17:55:18.674 [INFO ] [.smarthome.model.script.rules.blinds] - loop current state as Number FF_Blinds_Tobias: 4
2019-11-17 17:55:18.877 [INFO ] [.smarthome.model.script.rules.blinds] - Initial state2: 77
2019-11-17 17:55:18.877 [INFO ] [.smarthome.model.script.rules.blinds] - Shutter position2: 77
2019-11-17 17:55:18.878 [INFO ] [.smarthome.model.script.rules.blinds] - Received command2: 77
2019-11-17 17:55:18.878 [DEBUG] [.smarthome.model.script.rules.blinds] - delete timer.
Is there anyway to read the ACTUAL state during the move of the blinds?
So e.g. we start at ‘0’ and it is set to ‘50’ that I can read the state of 0,1,2,3,4,5,6 etc etc untill 50?
/Jasper
