Thanks. I am so impatient. No the device is still back in my system. The next steps will be done in the next days or at the weekend.
Problem solved. The nightly build instead of the last beta solved all my problemes. Systems is still working now.
Thanks to all
Sorry for reactivation of this old topic, but actually, i can still observe this issue with “binding-zwave - 2.4.0.M4”. It’s only battery level and temperature that is updated regulary. Other alarms remains undefined. Even i trigger polling manually:
2018-11-07 23:51:02.667 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Command received zwave:device:512:node27:alarm_smoke --> REFRESH
2018-11-07 23:51:02.671 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling intialised at 1800 seconds - start in 50 milliseconds.
2018-11-07 23:51:02.680 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Command received zwave:device:512:node27:alarm_heat --> REFRESH
2018-11-07 23:51:02.682 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling intialised at 1800 seconds - start in 50 milliseconds.
2018-11-07 23:51:02.687 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Command received zwave:device:512:node27:alarm_smoke --> REFRESH
2018-11-07 23:51:02.694 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling intialised at 1800 seconds - start in 50 milliseconds.
2018-11-07 23:51:02.704 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Command received zwave:device:512:node27:alarm_system --> REFRESH
2018-11-07 23:51:02.707 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling intialised at 1800 seconds - start in 50 milliseconds.
2018-11-07 23:51:02.710 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Command received zwave:device:512:node27:sensor_temperature --> REFRESH
2018-11-07 23:51:02.713 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling intialised at 1800 seconds - start in 50 milliseconds.
2018-11-07 23:51:02.719 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Command received zwave:device:512:node27:alarm_tamper --> REFRESH
2018-11-07 23:51:02.721 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling intialised at 1800 seconds - start in 50 milliseconds.
2018-11-07 23:51:02.725 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Command received zwave:device:512:node27:battery-level --> REFRESH
2018-11-07 23:51:02.728 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling intialised at 1800 seconds - start in 50 milliseconds.
2018-11-07 23:51:02.778 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling...
2018-11-07 23:51:02.781 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling zwave:device:512:node27:sensor_temperature
2018-11-07 23:51:02.784 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 27: Generating poll message for COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2018-11-07 23:51:02.787 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 27: Creating new message for command SENSOR_MULTILEVEL_GET
2018-11-07 23:51:02.789 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2018-11-07 23:51:02.792 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Command Class COMMAND_CLASS_SENSOR_MULTILEVEL is NOT required to be secured
2018-11-07 23:51:02.796 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling zwave:device:512:node27:alarm_heat
2018-11-07 23:51:02.800 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling zwave:device:512:node27:alarm_smoke
2018-11-07 23:51:02.802 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling zwave:device:512:node27:alarm_system
2018-11-07 23:51:02.805 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling zwave:device:512:node27:alarm_tamper
2018-11-07 23:51:02.807 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Polling zwave:device:512:node27:battery-level
2018-11-07 23:51:02.809 [DEBUG] [rnal.converter.ZWaveBatteryConverter] - NODE 27: Generating poll message for COMMAND_CLASS_BATTERY endpoint 0
2018-11-07 23:51:02.812 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_BATTERY
2018-11-07 23:51:02.814 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Command Class COMMAND_CLASS_BATTERY is NOT required to be secured
2018-11-07 23:51:02.817 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Bump transaction 10168 priority from Get to Immediate
2018-11-07 23:51:02.819 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Adding to device queue
2018-11-07 23:51:02.821 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Transaction already in queue - removed original
2018-11-07 23:51:02.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Added to queue - size 6
2018-11-07 23:51:02.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Bump transaction 10169 priority from Get to Immediate
2018-11-07 23:51:02.831 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Adding to device queue
2018-11-07 23:51:02.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Transaction already in queue - removed original
2018-11-07 23:51:02.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Added to queue - size 6
2018-11-07 23:52:05.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2018-11-07 23:52:05.575 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2018-11-07 23:52:05.577 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Is awake with 2 messages in the queue
2018-11-07 23:52:05.579 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Start sleep timer at 1000ms
2018-11-07 23:52:05.580 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2018-11-07 23:52:05.616 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 27: Node Status event - Node is AWAKE
2018-11-07 23:52:05.618 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2018-11-07 23:52:05.619 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@fe2264.
2018-11-07 23:52:05.630 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 27: Sending REQUEST Message = 01 0B 00 13 1B 04 31 04 01 00 25 E4 0D
2018-11-07 23:52:05.657 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 27: sentData successfully placed on stack.
2018-11-07 23:52:05.662 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: TID 10168: Transaction not completed
2018-11-07 23:52:05.934 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 27: SendData Request. CallBack ID = 228, Status = Transmission complete and ACK received(0)
2018-11-07 23:52:05.935 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2018-11-07 23:52:05.938 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: TID 10168: Transaction not completed
2018-11-07 23:52:06.075 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2018-11-07 23:52:06.077 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2018-11-07 23:52:06.081 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: WakeupTimerTask 2 Messages waiting, state DONE
2018-11-07 23:52:06.080 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2018-11-07 23:52:06.085 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2018-11-07 23:52:06.087 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_SENSOR_MULTILEVEL V8 SENSOR_MULTILEVEL_REPORT
2018-11-07 23:52:06.089 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 27: Sensor Type = Temperature(1), Scale = 0
2018-11-07 23:52:06.092 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 27: Sensor Value = 21.5
2018-11-07 23:52:06.094 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2018-11-07 23:52:06.096 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 21.5
2018-11-07 23:52:06.099 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:512:node27:sensor_temperature to 21.5 °C [QuantityType]
2018-11-07 23:52:06.104 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2018-11-07 23:52:06.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1749c14.
2018-11-07 23:52:06.109 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1749c14.
2018-11-07 23:52:06.111 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: notifyTransactionResponse TID:10168 DONE
2018-11-07 23:52:06.117 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-11-07 23:52:06.139 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 27: Sending REQUEST Message = 01 09 00 13 1B 02 80 02 25 E5 BE
2018-11-07 23:52:06.169 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 27: sentData successfully placed on stack.
2018-11-07 23:52:06.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: TID 10169: Transaction not completed
2018-11-07 23:52:06.424 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 27: SendData Request. CallBack ID = 229, Status = Transmission complete and ACK received(0)
2018-11-07 23:52:06.425 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2018-11-07 23:52:06.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: TID 10169: Transaction not completed
2018-11-07 23:52:06.552 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2018-11-07 23:52:06.554 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2018-11-07 23:52:06.556 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2018-11-07 23:52:06.557 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_BATTERY
2018-11-07 23:52:06.559 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2018-11-07 23:52:06.561 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 27: Battery report value = 100
2018-11-07 23:52:06.563 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-11-07 23:52:06.565 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BATTERY, value = 100
2018-11-07 23:52:06.567 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Updating channel state zwave:device:512:node27:battery-level to 100 [DecimalType]
2018-11-07 23:52:06.572 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2018-11-07 23:52:06.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@ad3a27.
2018-11-07 23:52:06.575 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@ad3a27.
2018-11-07 23:52:06.576 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: notifyTransactionResponse TID:10169 DONE
2018-11-07 23:52:06.578 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-11-07 23:52:06.582 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: WakeupTimerTask 0 Messages waiting, state DONE
2018-11-07 23:52:07.081 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: WakeupTimerTask 0 Messages waiting, state DONE
2018-11-07 23:52:07.083 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: No more messages, go back to sleep
2018-11-07 23:52:07.086 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 27: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2018-11-07 23:52:07.087 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2018-11-07 23:52:07.090 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2018-11-07 23:52:07.094 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@10047b0
2018-11-07 23:52:07.097 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Bump transaction 10170 priority from Immediate to Immediate
2018-11-07 23:52:07.100 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Adding to device queue
2018-11-07 23:52:07.104 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Added to queue - size 5
2018-11-07 23:52:07.117 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 27: Sending REQUEST Message = 01 09 00 13 1B 02 84 08 25 E6 B3
2018-11-07 23:52:07.153 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 27: sentData successfully placed on stack.
2018-11-07 23:52:07.157 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: TID 10170: Transaction not completed
2018-11-07 23:52:07.361 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 27: SendData Request. CallBack ID = 230, Status = Transmission complete and ACK received(0)
2018-11-07 23:52:07.363 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2018-11-07 23:52:07.366 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Response processed after 242ms
2018-11-07 23:52:07.368 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: TID 10170: Transaction completed
2018-11-07 23:52:07.370 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: notifyTransactionResponse TID:10170 DONE
2018-11-07 23:52:07.371 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 27: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-11-07 23:52:07.374 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Went to sleep COMPLETE
Parmater 2 is enabled:
and association is set to Z-Wave controller:
Items definition:
Number B_SmokeSensor_BatteryLevel "Smoke" {channel="zwave:device:512:node27:battery-level", expire="7h"}
Number B_SmokeSensor_Temperature "Temperature" {channel="zwave:device:512:node27:sensor_temperature"}
Switch B_SmokeSensor_AlarmSystem "System [MAP(failure.map):%s]" {channel="zwave:device:512:node27:alarm_system"}
Switch B_SmokeSensor_AlarmTamper "Tamper [MAP(failure.map):%s]"{channel="zwave:device:512:node27:alarm_tamper"}
Switch B_SmokeSensor_AlarmSmoke "Smoke [MAP(fire.map):%s]"{channel="zwave:device:512:node27:alarm_smoke"}
Switch B_SmokeSensor_AlarmHeat "Heat [MAP(fire.map):%s]" {channel="zwave:device:512:node27:alarm_heat"}
and fire.map:
NULL=?
ON=Fire!
OFF=OK
When doing somke test i could see that B_SmokeSensor_AlarmSmoke
item was correctly set. However, i would like get updates regarding status when there is no fire as well. Is it possible with this device or this is some bug?
