I’m trying to read data from my Iskrameco MT372 meter via the TCP binding, but the binding is giving me a big headache…
The meter is quite slow in responding, which seems to make the binding end it’s receive buffering so I’m unsure how to solve this. I thought that blocking=true would solve it, but it doesn’t :(. Also no matter what I try, then I cannot get another Item to receive the data, it’s always the sending item which gets the response…
tcp.cfg:
port=25001
postamble=\r\n
blocking=true
timeout=8000
refreshinterval=8000
charset=ASCII
rule:
rule "Ask Iskrameco"
when Item RedButton changed to ON
sendCommand(SmartMeter_send,"/?!")
try { Thread::sleep(2000) } catch(Exception e) {}
sendCommand(SmartMeter_send,"000")
Item:
String SmartMeter_send "SmartMeter [%s]" (SmartMeter) {tcp=">[192.168.1.20:4002:default]", autoupdate="false" }
I should in the second query receive e.g. (tested with putty):
1.8.0(34581.690kWh)
2.8.0(20074.272kWh)
21.7.0((ER11))
31.7.0(002.9A)
32.7.0(230V)
41.7.0((ER11))
51.7.0(003.4A)
52.7.0(229V)
61.7.0((ER11))
71.7.0(002.2A)
72.7.0(232V)
But I only get:
1.8.0(34581.439kWh)
2.8.0(20074.272kWh)
21.7.0((ER11))
so a lot of data is missing
