Recommendable wired heating control system
Arrr, again you can’t push a value into a VMB4AN, you can only read the values, or the output states that the logic inside the VMB4AN decides.
Not really, because of the above.
However… Not to be outdone…
There’s no reason why the Thermostat logic can’t be done in a stand alone openHAB2 / Node-RED instance and push relay status updates into Velbus relays. (Or any other brand for that matter)
It wouldn’t be my first choice, but there are plenty of examples of people using openHAB2 as Thermostats with very advanced timings.
@ThomDietrich Thermostat boilerplate would be an excellent start.
