recently I wondered if a customized widget can call itself using different parameter. It turned out …
yes - yes it can.
The following widget has several parameters which are not used when you first open the widget. If you click on the widget (in this case one of the mock-ups) the defined action is to open the same widget in a popup with a different set of the parameters to this entity.
The parameter Do Not Configure is for example only used in this second round.
The widget shows
- the live view of my porch,
- a mockup of pictures from the Doorbell-event
- a mockup of pictures from the Motion-event
If you click on the mockup, the popup shows who used the doorbell (or who triggered the movement). You can also see the time and can go through the events with a stepper.
uid: Doorbird
props:
parameters:
- description: Label
label: Label
required: false
type: TEXT
groupName: groupLive
- context: item
description: Image
label: Image
required: true
type: TEXT
- context: item
description: Timestamp
label: Timestamp
required: false
type: TEXT
- description: Label for the Doorbell Image Card
label: Label
required: false
type: TEXT
groupName: groupDoorbell
- context: item
description: Historic Doorbell Image Item
label: Image (History)
required: false
type: TEXT
- context: item
description: Historic Doorbell Image Timestamp Item
label: Timestamp (History)
required: false
type: TEXT
- context: item
description: Historic Doorbell Image Index Item
label: Index (History)
required: false
type: TEXT
- context: item
description: Doorbell Image Montage
label: Montage
required: false
type: TEXT
- description: Label for the Motion Image Card
label: Label
required: false
type: TEXT
groupName: groupMotion
- context: item
description: Historic Motion Image Item
required: false
type: TEXT
- context: item
description: Historic Motion Image Timestamp Item
required: false
type: TEXT
- context: item
description: Historic Motion Image Index Item
required: false
type: TEXT
- context: item
description: Motion Image Montage
label: Montage
required: false
type: TEXT
- context: item
description: Do Not Configure
label: Do Not Configure
required: false
type: TEXT
groupName: groupDump
parameterGroups:
- name: groupLive
label: Live Image
- name: groupDoorbell
label: Doorbell Image
- name: groupMotion
label: Motion Image
- name: groupDump
timestamp: Jun 5, 2021, 9:54:02 PM
component: f7-card
slots:
default:
- component: oh-image
lazy: true
position: absolute
item: =props.imageCurrent
style:
maxWidth: 100%
height: auto
- component: f7-chip
visible: =(props.labelCurrent !== undefined)
text: =props.labelCurrent
style:
position: absolute
color: white
top: 0px
left: 0px
visible: =(props.timestampCurrent !== undefined)
text: =items[props.timestampCurrent].displayState
style:
position: absolute
color: white
top: 30px
left: 0px
- component: oh-stepper
visible: =(props.recursiveIndex !== undefined)
style:
position: absolute
top: 60px
left: 0px
item: =props.recursiveIndex
lazy: true
position: absolute
item: =props.imageMontageOne
action: popup
actionModal: widget:Doorbird
actionModalConfig:
labelCurrent: =props.labelDoorbell
imageCurrent: =props.imageDoorbellHistory
timestampCurrent: =props.timestampDoorbellHistory
imageMontageOne: =props.imageMontageOne
recursiveIndex: =props.indexDoorbellHistory
style:
maxWidth: 100%
height: auto
visible: =(props.labelDoorbell !== undefined)
text: =props.labelDoorbell
position: absolute
top: 0px
left: 30px
lazy: true
position: absolute
item: =props.imageMontageTwo
action: popup
actionModalConfig:
labelCurrent: =props.labelMotion
imageCurrent: =props.imageMotionHistory
timestampCurrent: =props.timestampMotionHistory
imageMontageOne: =props.imageMontageTwo
recursiveIndex: =props.indexMotionHistory
style:
maxWidth: 100%
height: auto
visible: =(props.labelMotion !== undefined)
text: =props.labelMotion
position: absolute
top: 0px
left: 0px
Hope this is for any use for others - have fun.
Best regards
Peter
