Hi All
I am trying to redirect by GPSTRACKER Binding logs to a separate file to do some debugging.
EDIT
- Platform information:
- Hardware: CPUArchitecture/RAM/storage
- OS:Win 10 Pro
- Java Runtime Environment:Zulu 11.43.55
- openHAB version: OH 3.1 - SNAPSHOT
EDIT**
I have set org.openhab.binding.gpstracker to TRACE as follows:
log:set TRACE org.openhab.binding.gpstracker
org.openhab.binding.caddx | INFO
org.openhab.binding.gpstracker | TRACE
org.openhab.binding.harmony | INFO
I can also see logs when TRACE logs when running log:tail
18:19:29.356 [TRACE] [acker.internal.handler.TrackerHandler] - batteryLevel -> 51
18:19:29.356 [TRACE] [acker.internal.handler.TrackerHandler] - lastLocation -> <REDACT>
18:19:29.356 [TRACE] [acker.internal.handler.TrackerHandler] - lastReport -> 2021-03-13T18:19:27.000+0200
I have tried to make the following changes to the log4j2.xml file as found on the forum.
<!-- Rolling file appender -->
<RollingGPS fileName="${sys:openhab.logdir}/gpstracker.log" filePattern="${sys:openhab.logdir}/gpstracker.log.%i" name="GPSTRACKER">
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
<Policies>
<OnStartupTriggeringPolicy/>
<SizeBasedTriggeringPolicy size="16 MB"/>
</Policies>
</RollingGPS>
<Logger additivity="false" level="TRACE" name="org.openhab.binding.gpstracker">
<AppenderRef ref="GPSTRACKER"/>
</Logger>
Also tried using “RollingFile” instead of “RollingGPS” - I read somewhere that they had to be distinct.
Full file as follows:
log4j2.xml (5.6 KB)
I have restarted OpenHab etc, but I still dont get a new log file…
Any suggestions?
Mark
