Is there any way to use the template widget to essentially fresh the page back to the initial habpanel after a set time?
Example if I have say “Living Room”, “Hallway” “Garage” and as dashboards and I select “Living Room” can a time be set so that it goes back to show the main index for all rooms “http://:8080/habpanel/index.html#/”.
My idea is to run a 7’’ touch screen with habpanel as a control centre but want it to default to the main index page when theres been no activity for a set time, needs to be something I can set per dashboard as I might not want it to happen on all or might want it to have different refresh time values.
Ok so doesn’t look like theres any takers on this one which is a shame.
I have tried using a “template” and “META HTTP-EQUIV=refresh” which kind of works but produces an unsightly white screen for the few seconds it takes to refresh back, works but not pretty so still hoping for a more graceful solution.
Example:
META HTTP-EQUIV=“refresh” CONTENT=“300; URL=http://kiosk1:8081/habpanel/index.html#”>
Doesn’t work for all browsers, but guessing thats down to browser settings more than anything else, tested with chromium kiosk but as I mentioned produces a white screen when transitioning.
