I’m having a question ever since I migrated my system RPI 3B+ running OH 3.01 migratied from OH 2.5 while system already was in netboot to a cardless netboot system my configuration files Items Rules etc never refreshes due to saved changese in files. I read about it and it could be caused by network file events are diffrent from OS file events.
Is there a way to not need to restart system for every change I do for example a script or rule that I cant trigg when I made some changes, even tough sometimes the best is to restart system completely.
If you login to your system via ssh and edit the file with “vi” or another editor and then save the file again it should reload the changes (check openhab.log) .
Hi yes that worked, I did even get touch and filename to work. I have som strange behaviour since migrating to netboot I can’t type cd /e tab button to get cd /etc/ to work iI get som error message on auto complete in commandline that I can’t create temporary files.
This is totally off topic but thought I could mention it.
