Refresh Item when certain MQTT message is received
  • Platform information:
    • Hardware: Raspberry Pi 3 Model B Rev 1.2
    • OS: Raspbian GNU/Linux 10
    • openHAB version: 2.5.6-2 (Release Build)
Hello everyone,
I have connected 2 Tradfri switches and two different LEDs from IKEA to my Zigbee2MQTT and subsequently to my Openhab. I can control the Lights from Openhab and also from the switches (by binding them in zigbee2mqtt).
My problem is: When I use the (IKEA hardware) switches to turn the lights on or off, change brightness etc. Openhab doesn’t realize that. I have set up rule with a cronjob that simply runs a mosquitto_pub to get the current values:
executeCommandLine(“mosquitto_pub -h localhost -t zigbee2mqtt/Licht_Vitrine/get/state -m ""”)
executeCommandLine(“mosquitto_pub -h localhost -t zigbee2mqtt/Licht_Kommode/get/state -m ""”)
however, that is not quite elegant. I was looking for making a rule that triggers when I receive the button press in my mqtt broker, e.g.:
Client mosqsub|3127-openhab received PUBLISH (d0, q0, r0, m0, ‘zigbee2mqtt/SchalterVitrine’, … (71 bytes))
{“linkquality”:118,“update_available”:false,“battery”:16,“click”:“off”}
I found serveral posts about creating an item and binding it to the mqtt, but these are apparently all for MQTT 1. Since I got MQTT 2 that doesn’t work.
Does anyone have an idea how to get this running?
Kind Regards,
Christoph Bismark
don’t the lights publish a state on change?
With an mqtt “thing” there’s a command topic for setting the state and a state topic for receiving a state.
This is pretty close to the setup of a switch:
Bridge mqtt:broker:mqttBroker [ host="192.168.x.x", secure=false ]
	Thing topic mqttTest "mqttTest" {
		Channels:
			Type switch : mqttSwitch "MQTTSwitch" [ stateTopic="MQTTSwitch/State", commandTopic="MQTTSwitch/Command" ]
Also with zigbee2mqtt there’s a setting, that will push everything to a topic, rather than needing json transformations of every item:
experimental:
  output: attribute
Source: Zigbee2mqtt revisited: No more ugly transformations
I suppose you would set up MQTT (v2) Things and channels to listen for button presses, link to Item(s).
Then a rule triggered by button Items can predict the effect and update the light Items directly. Or invoke your light status refresh code.
It’s all a bit of a kludge, I’d be looking to have the IKEA lights report when they change.
I do have stateTopic defined:
Type switch : onoff “Schalter Vitrine” [stateTopic=“zigbee2mqtt/Licht_Vitrine”, transformationPattern=“JSONPATH:$.state”, commandTopic=“zigbee2mqtt/Licht_Vitrine/set”, transformationPatternOut=“JS:tradfriStateTransform.js”]
But apparently since I have bound the switch to the Light Group directly, the stateTopic seems to not be published when I press the hardware button?
Regards,
Christoph
Not sure what that means.
Have you got an Item bound to your MQTT generic Thing switch-type channel? Is it a Switch type Item?
Presumably they’ve linked/paired the switch directly to the bulb, through (IKEA’s?) Zigbee protocol…
Hello everyone,
I have bound the switch to a certain group in my zigbee2mqtt configuration. But I have now found the config-option
advanced:
report: true
in the configuration.yaml. Now it works automagically :slight_smile:
Regards,
Christoph
