it’s a general problem. As example if I use a Selection in the Sitemap this will not refresh the sitemap. I have to press F5 and then I see the change.
I have made an ugly solution that the sitemap could be refreshed every 5 seconds:
My HTML-Code
<!DOCTYPE html>
<html>
<head>
<title>Automatische Seitenaktualisierung</title>
<script type="text/javascript">
// JavaScript, um die Seite alle 5 Sekunden neu zu laden
setInterval(function() {
window.top.location.reload();
}, 5000); // 5000 Millisekunden (5 Sekunden)
</script>
</head>
<body>
</body>
</html>
I found out that window.location.reload();
only reloads my Webview. So I changed it to window.top.location.reload();
The big advantage is that if you open as example the Menu from a Selection the page could be refreshed and this will close the Selection before you have selected anything.
I added this to my Sitemap:
Webview url="/static/sitemaps/auto_reloader.html" icon=none
I have one more thought. Maybe it is possible to divide some things into different frames and reload single frames at the end instead of the whole sitemap. But I still have no idea how to implement this.
Is there another solution? I have also thought about writing a script that simply generates HTML pages with JavaScript / jQuery code for sitemaps, which are then reloaded asynchronously.
Love greetings
Michael
