Any change in mqtt.items file causing adding or remove links triggers rules with “System started” Is it correct behaviour ? Tried restarting OH, removing/changing rules and items and it happens even with this simple config:
mqtt.items
String swiatloWarsztat_Reachable "Aktywny: [%s]" <contactable> (gT_lwt) { channel="mqtt:topic:swiatloWarsztat:reachable" }
Number swiatloWarsztat_RSSI "WiFi [%d %%]" <wifi> (gT_rssi) { channel="mqtt:topic:swiatloWarsztat:rssi" }
Switch swiatloWarsztat "Warsztat" <light> (g_swiatla) { channel="mqtt:topic:swiatloWarsztat:power", channel="mqtt:topic:swiatloWarsztat:state_power" }
system_started.rule
rule "test rule"
System started
logInfo("RULE","system_started rule triggered after mqtt.items reload")
Then i changed swiatloWarsztat to swiatloWarsztat1
logs:
==> /logs/openhab.log <==
2020-09-23 10:21:09.281 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'mqtt.items'
==> /logs/events.log <==
2020-09-23 10:21:09.283 [.ItemChannelLinkAddedEvent] - Link 'swiatloWarsztat1-mqtt:topic:swiatloWarsztat:power' has been added.
2020-09-23 10:21:09.283 [.ItemChannelLinkAddedEvent] - Link 'swiatloWarsztat1-mqtt:topic:swiatloWarsztat:state_power' has been added.
2020-09-23 10:21:09.283 [temChannelLinkRemovedEvent] - Link 'swiatloWarsztat => mqtt:topic:swiatloWarsztat:power' has been removed.
2020-09-23 10:21:09.284 [temChannelLinkRemovedEvent] - Link 'swiatloWarsztat => mqtt:topic:swiatloWarsztat:state_power' has been removed.
2020-09-23 10:21:16.514 [INFO ] [.eclipse.smarthome.model.script.RULE] - system_started rule triggered after mqtt.items reload
