Hello
I have a little problem with REGEX and the MQTT binding.
The MQTT binding and switch works great without regex.
{mqtt="<[mqtt1:RFLinkR:state:20;2A;Chuango;ID=b1b978;SWITCH=02;CMD=ON;]"}
I think the regex transformation also work fine … when i type a invalid regex i get an error.
But both i cant get to work
My MQTT message: 20;2A;Chuango;ID=b1b978;SWITCH=02;CMD=ON;
I simple want to look after: Chuango;ID=b1b978
So if Chuango;ID=b1b978 is in the message turn the switch on.
My MQTT for the Item:
{mqtt="<[mqtt1:RFLinkR:state:ON:REGEX(.(Chuango);(ID=b1b978).)]"}
I have tried:
.(Chuango;ID=b1b978).
…(Chuango;ID=b1b978)…
And much more valid regex strings but it dosent work.
I have also tried it with state and command.
I get no error and the switch wont switch …
Thanks and sorry for my bad english …
I figured out that the regex work to …
When i use the mqtt string without the ON i get the following warning:
given new state is NULL, couldn’t post update for ‘AL_WHGT’
So i used:
{mqtt="<[mqtt1:RFLinkR:state:REGEX(.(Chuango);(ID=b1b978).)]"}
not
{mqtt="<[mqtt1:RFLinkR:state:on:REGEX(.(Chuango);(ID=b1b978).)]"}
So i think the regex will work to but why i dosent work with the on state …
thanks
Ok now i found the solution thanks
You cant use the REGEX to switch item states only for number or string items …
To switch item states you have to use regex_filter !
First i thougt it will be the same but it isnt and there is no example in the mqtt binding description …
The difference just simple write the regex without the REGEX in front.
So you have to use for switches or switchable items:
{mqtt="<[mqtt1:RFLinkR:state:ON:.*(Chuango);(ID=b1b978).*]"}
For Numbers, Strings etc. you have to use something like this to get a part of the message:
{mqtt="<[mqtt1:RFLinkR:state:REGEX(.*(Chuango);(ID=b1b978).*)]"}
