- Platform information:
- Hardware: lxc/RAM 4gb/storage 32g
- OS: debian 11
- Java Runtime Environment: 17.0.9
- openHAB version: 4.0.4
I encountered an unexpected problem. When I add a new thing to one of the channels, I get a known error.
`[WARN ] [t.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.ZbReceived.kitchen_th_2.BatteryPercentage' in '{"ZbReceived":{"kitchen_th_2":{"Device":"0x6391","Name":"kitchen_th_2","Temperature":25.23,"Humidity":34.35,"Endpoint":1,"LinkQuality":160}}}'`
The fact is that I completely copy the configuration of a previously created thing (which has been working on another installation for a long time) but for a different object. Naturally with adaptation to his topic.
Config channels -
channels:
- id: kitchen_th_2_t
channelTypeUID: mqtt:number
label: kitchen_th_2_t
description: null
configuration:
stateTopic: tele/zb_bridge/kitchen_th_2/SENSOR
transformationPattern: REGEX:(.*Temperature.*)∩JSONPATH:$.ZbReceived.kitchen_th_2.Temperature
- id: kitchen_th_2_b
label: kitchen_th_2_b
description: ""
configuration:
transformationPattern: REGEX:(.*BatteryPercentage.*)∩JSONPATH:$.ZbReceived.kitchen_th_2.BatteryPercentage
In this case, the temperature channel works normally.
It seems the regular expression is not taken into account at all.
It looks like I’m missing something obvious, but I’ve been struggling all day to no avail.
Maybe this has something to do with version updates?
I would appreciate any comments.
