when i run the HTTP api command for power state on my tasmota device i get {"POWER":"OFF"}
I get ON or OFF state so this ITEM file works! String SonoffVarmareGV "Sonoff GetValue" { http="<[http://192.168.1.82/cm?user=admin&password=ksldjflksdf&cmnd=Power:10000:REGEX(.*?\\{\"POWER\":\"(.*?)\"\\}.*)]"}
but when i HTTP api my tasmota device and want only to read out Temperature with REGEX?
What does this mean - do you get an error or warning in the openHAB logs?
I’m only familiar with Tasmota over MQTT, where the JSONPATH would usually be:
JSONPATH($.DS18B20.Temperature)
Might be worth trying, but it shouldn’t based on your JSON extract you showed in your OP. EDIT: I see now that you’re calling STATUS 10, so your original JSON extract looks correct.
