I want to explain why your REGEX didn’t work so you are better able to create them in the future.
There are a couple of odd behaviors in the way the REGEX transform works in openHAB. The biggest quirk is that the transform must match the entire string and it’s the first matching group (i.e. ( )) that gets returned. Your regex fails on the first point, it only matches Strings that consist of five characters so it skips the messages you are receiving which have 8 characters.
It is possible to adjust your REGEX to work. REGEX:(.....).*
@Udo_Hartmann’s solution is even better because it is more precise. It matches one or more digits, a decimal point, and zero or more digits. So if you got a message like “error” your REGEX would match but Udo’s would not.
But we can make Udo’s even better. Currently it won’t support a minus sign and the decimal point is required to be there.
REGEX:([-]?\d+[\.]?\d*);.*
That should match and return the negative sign if it’s present, one or more digits, optionally match a decimal point, and then zero or more digits, ignoring the “;” and everything after that.
But beware, I just typed this in and it’s not tested.
