Hey,
Finally getting around to resolving another quibble I encountered up upgrading from 2.0 to 2.1 - the regular expressions in my voice command rule.
If the simple lines below are not commented out:
var Pattern p = Pattern::compile(".* ([0-9]+)\%.*")
var Matcher m = p.matcher(command)
if (m.matches()) {
newState = new String(m.group(1).trim())
I get [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘helps.rules’ has errors, therefore ignoring it: [583,54]: Invalid escape sequence (valid ones are \b \t \n \f \r " ’ \ )
It used to work fine in 2.0, so what has changed in how I have to wrap/escape characters there?
