I am new to openHAB and esp8266. I want to build my self a smart light switch which consists of a two channel relay board and esp8266-01. I want to control the relay with MQTT from the openHAB app on my phone. But i need help with the code for the esp8266. I did some research in google but i haven`t found anything related to my problem. I am aware of sonoff and the other already made devices i want to make my own device as a project for my home.
THANKS in advance!
Use the homie-framework.
I found an example in Homie called lightonoff but can it interact with openhab via MQTT i cant see where can i enter my wi-fi creadentials or both device can discover each other without that?
Send me a PM
I have some code
It’s for a sonoff but it will work on any ESP8266 board
Just make sure you use the right pins
I cant seem to find how to PM you. Maybe cause i`m a new member. Can you PM me?
Click on the avatar and then on “Message”
Could you send me the code too, please ?
Can you please share me code.
Hi Could you please send me code.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Bounce2.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
const char* ssid = "SSID"; //SSID WIFI Access Point
const char* password = "password"; //Access Point Password
const char* mqtt_server = "XXX.XXX.XXX.XXX"; //IP address MQTT server
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
const char* inTopic = "House/LivingRoom/AquariumPump"; // MQTT Topic this switch subscribes ("listens" to
const char* switchTopic = "House/LivingRoom/AquariumPumpStatus"; //MQTT Topic wall switch publish
int relay_pin = 12; //Pin for Relay
int button_pin = 0; //Pin for button
int switch_pin = 14; //Pin for ext switch
bool relayState = HIGH;
// Instantiate a Bounce object - used for built in button to toggle relay on/off:
Bounce debouncer = Bounce();
Bounce debouncer2 = Bounce();
unsigned long previousMillis = 0; // will store last time STATUS was send to MQTT
const long interval = 60000; //one minute for status refresh
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
extButton();
for(int i = 0; i<500; i++){
extButton();
delay(1);
Serial.print(".");
digitalWrite(13, LOW);
delay(500);
digitalWrite(13, HIGH);
delay(500);
delay(500);
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
// Switch on the RELAY if an "1" was received as first character or OFF if first character was a "0" or toggle relay when received a "2"
if ((char)payload[1] == 'F') {
digitalWrite(13, HIGH); // Turn LED OFF
digitalWrite(relay_pin, LOW); // Turn the RELAY OFF
relayState = LOW;
} else if ((char)payload[1] == 'N') {
digitalWrite(13, LOW); // Turn LED OFF
digitalWrite(relay_pin, HIGH); // Turn the RELAY ON by making the voltage HIGH
relayState = HIGH;
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("SonoffAquariumPump", "MQTTUsername", "MQTTPassword")) {
Serial.println("connected");
// Once connected, publish an announcement to $State...
// client.publish($State, "I am ON", true);
//Send WIFI Signal Strength
long rssi = WiFi.RSSI();
char sig[50];
sprintf(sig, "%d.%02d", (int)rssi, (int)(rssi*100)%100);
client.publish($Signal, sig, true);
//Send IP address of node
char buf[16];
sprintf(buf, "%d.%d.%d.%d", WiFi.localIP()[0], WiFi.localIP()[1], WiFi.localIP()[2], WiFi.localIP()[3] );
// client.publish($IP, buf, true);
//Subscribe to incoming commands
client.subscribe(inTopic);
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
for(int i = 0; i<5000; i++){
extButton();
delay(1);
void extButton() {
debouncer.update();
// Call code if Bounce fell / onboard button pushed (Toggle from HIGH to LOW) :
if ( debouncer.fell() ) {
Serial.println("Debouncer fell");
// Toggle relay state :
relayState = !relayState;
digitalWrite(relay_pin,relayState);
if (relayState == 1){
client.publish(switchTopic, "ON", false);
else if (relayState == 0){
client.publish(switchTopic, "OFF", false);
void updatecall() {
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
// save the last time status was send
previousMillis = currentMillis;
void setup() {
String line = "";
pinMode(relay_pin, OUTPUT); // Initialize the relay pin as an output
pinMode(button_pin, INPUT); // Initialize the relay pin as an input
pinMode(switch_pin, INPUT_PULLUP);
pinMode(13, OUTPUT); // Initialize the onboard LED as output
debouncer.attach(button_pin); // Use the bounce2 library to debounce the built in button
debouncer.interval(50); // Input must be low for 50 ms
debouncer2.attach(switch_pin);
debouncer2.interval(50);
digitalWrite(13, LOW); // Blink to indicate setup
delay(50);
delay(50);
Serial.begin(115200);
setup_wifi(); // Connect to wifi
client.setServer(mqtt_server, 1883); //connect to MQTT
client.setCallback(callback);
Serial.println("Ready");
Serial.print("IP address: ");
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
extButton();
