New beta is not workin! Same issue as described above:
HTTP ERROR 500
Problem accessing /amazonechocontrol/8ddd4dbe/ap/signin/135-3435306-60732911. Reason:
Server Error
Caused by:
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://www.amazon.com/ap/signin/135-3436306-' failed: Moved Temporarily
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:628)
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.handleProxyRequest(AccountServlet.java:628)
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doVerb(AccountServlet.java:225)
at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doPost(AccountServlet.java:133)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.Server.handle(Server.java:531)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680)
at java.lang.Thread.run(Thread.java:748)
Im guessing the answer to this will be no as stated many times before it can only do what you can do on the web interface - so my next thought is to via a rule stop the alarm and create a new alarm in 10 mins on each button press (not sure if possible as doco doesnt say you can stop or create an alarm - only play an alarm sound), option 2 is to change the volume of the alarm via a rule to 0 then bing it back up to full in 10 mins (doco does say you can change alarm volume but no example of this) i am assuming alarms go forever.
I could also write a custom rule to program an alarm sound and do whatever I want with it then, but am trying not to lose the WAF where she can tell Alexa āset an alarm for 7am every weekdayā by making it purely openhab.
Love to hear from anyone else doing this
Will report back any progress.
Thank you for all your hard work here! I have been using the binding for a while now and have to say I Love it! It was working flawlessly for me but recently i started to have some issues with my Alexa Routine Rules I set. I canāt figure out if there is an issue with the code or something else. Below is the code I am using in my Alexa.Rules file.
//ALexa Dinner Time
rule "Dinner Time On"
Item dinner_mode changed to ON
Echo_Living_Room_StartRoutine.sendCommand('Turn On Dinner')
//ALexa Dinner Time Off
rule "Dinner mode off"
Item dinner_mode changed to OFF
All_Lights_Switch.sendCommand(ON)
//ALexa Mood Mode On
rule "Mood Mode On"
Item mood_lights changed to ON
Echo_Living_Room_StartRoutine.sendCommand('Turn on the Mood Lights')
//Turn Off Mood Mode
rule "Mood Mode Off"
Item mood_lights changed to OFF
Echo_Living_Room_PlayMusicCommand.sendCommand('stop')
//ALexa Turn on the Kitchen Cabinets
rule "Kitchen Cabinets On"
Item kitchen_cabinets changed to ON
Echo_Living_Room_StartRoutine.sendCommand('turn on dots')
//ALexa Turn Off the Kitchen Cabinets
rule "Kitchen Cabinets Off"
Item kitchen_cabinets changed to OFF
Echo_Living_Room_StartRoutine.sendCommand('turn off dots')
//ALexa Media Center On
rule "Media Center On"
Item media_center changed to ON
Echo_Living_Room_StartRoutine.sendCommand('turn on media center')
//ALexa Media Center Off
rule "Media Center off"
Item media_center changed to OFF
Echo_Living_Room_StartRoutine.sendCommand('turn off media center')
//ALexa Netflix Off
rule "Netflix off"
Item netflix changed to OFF
Echo_Living_Room_StartRoutine.sendCommand('close netflix')
//ALexa Netflix ON
rule "Netflix On"
Item netflix changed to ON
Echo_Living_Room_StartRoutine.sendCommand('open netflix')
//ALexa Bedroom Master On
rule "office master switch on"
Item office_master_switch changed to ON
Echo_Living_Room_StartRoutine.sendCommand('open office')
//ALexa Bedroom Master Off
rule "office master switch off"
Item office_master_switch changed to OFF
Echo_Living_Room_StartRoutine.sendCommand('close office')
//Good Night Mode Off
rule "All Lights Off"
Item good_night changed to OFF
Echo_Living_Room_StartRoutine.sendCommand('Good Night')
//Lights On
rule "Good Night"
Item good_night changed to ON
//ALexa Livingroom Blinds ON
rule "Livingroom Blinds Open"
Item livingroom_blinds changed to ON
Echo_Living_Room_StartRoutine.sendCommand('open the livingroom blinds')
//ALexa Livingroom Blinds OFF
rule "Livingroom Blinds Close"
Item livingroom_blinds changed to OFF
Echo_Living_Room_StartRoutine.sendCommand('close the livingroom blinds')
//ALexa Bedroom Blinds OFF
rule "Bedroom Blinds Close"
Item bedroom_blinds changed to OFF
Echo_Living_Room_StartRoutine.sendCommand('close the bedroom blinds')
//ALexa Bedroom Blinds ON
rule "Bedroom Blinds Open"
Item bedroom_blinds changed to ON
Echo_Living_Room_StartRoutine.sendCommand('open the bedroom blinds')
//ALexa Movie Mode ON
rule "Movie Mode On"
Item movie_lights changed to ON
Echo_Living_Room_StartRoutine.sendCommand('turn on movie mode')
//ALexa Movie Mode OFF
rule "Movie Mode Off"
Item movie_lights changed to OFF
Echo_Living_Room_StartRoutine.sendCommand('turn off movie mode')
To be clear everything was working perfectly and then I added some more routines and suddenly only some of them work now. Let me know if you have any suggestions or if there is something that I am doing wrong. Thanks for your help!
Hi Andrew thank you for your quick reply. I tried to upgrade from 2.3 to the latest release and I am getting the following error message. Are you aware how to fix the problem?
sudo apt-get upgrade
Reading package listsā¦ Done
Building dependency tree
Updating FireMotD available updates count ā¦ E: Malformed line 1 in source list /etc/apt/sources.list.d/influxdb.list (dist parse)
E: The list of sources could not be read.ectories currently installed.)d and is no longer required:
Preparing to unpack ā¦/python-ply_3.4-5_all.deb ā¦
OK
$ apt -y install apt-transport-https
Reading state informationā¦ Done
apt-transport-https is already the newest version.
The following package was automatically installed and is no longer required:
libc-ares2
Use āapt-get autoremoveā to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2019-04-24_06:40:46_EDT [openHABian] Installing or upgrading to latest openHAB release (stable)ā¦
$ wget -O openhab-key.asc https://bintray.com/user/downloadSubjectPublicKey?username=openhab
ā2019-04-24 06:40:47-- https://bintray.com/user/downloadSubjectPublicKey?username=openhab
Resolving bintray.com (bintray.com)ā¦
Connecting to bintray.com (bintray.com)|ā¦ connected.
HTTP request sent, awaiting responseā¦ 200 OK
Length: unspecified [application/octet-stream]
Saving to: āopenhab-key.ascā
$ apt update
$ apt-get -y install openhab2=
E: Version āā for āopenhab2ā was not found
FAILED (apt)
I just noticed when I go to /amazonechocontrol/my_account and click on one of the links under Thing, under capabilities some have really weird stuff like āpoptartā, āgoldfishā, ālemur_alphaā, and ādream_trainingā. Any idea what thatās all about? Iām guessing itās something like internal codewords or something and doesnāt mean much but it made me laugh
Confirming @Christoph_Zehās , @dastrix80ās and @oeoās issue with the latest Beta 2.5 (7): No way to log-in the Account thing. Canāt do anything with the binding right now. Any idea, @michi?
For the time being can anyone provide a download link for the Beta 2.5 (6) for downgrading?
Iām sure someone will have a link but its best to always make a back up of your current OH setup before upgrading, be it a single binding or a new version of OH. Doing this gets you back up and running, no need to rely on others.
Hi, Just a question.
Is it possible to start an Alexa skill command by Openhab?
For instance when someone ring on the door I would like Alexa start a voice skill command like āAlexa, play ā¦ā
Thanks for any adviceā¦
I believe this is still a problem, and can report the following:
I have a great working OpenHABian with the Beta 2.5 (7), I have everything in config files, I have a second Pi, SSD and installad a clean OpenHABian on it, copied the backup of my conf dir over and placed the 4 later .jarās in my addons dir, including the Beta 2.5 (7).
And I get the HTTP 500 error, and can not get it to work anymore! (So Iām running on my original version again, itās always nice to have a good working version )
