I still habe a instance of OH2 running.
So I have configured the remote binding on OH3 to get Items from the older server.
This works for the few items I have setup currentlx.
Now I would like to send some Items from OH3 to OH2.
But it does not seem to work.
I habe the Home Connect binding for my new washer configured on OH3.
Number:Time Waschmaschine_K_RemainingProgramTimeState "Remaining program time [JS(clockfmt.js):%s]" {channel="homeconnect:washer:api_bridge_k:waschmaschine_k:remaining_program_time_state", channel="remoteopenhab:server:oh2:Waschmaschine_K_RemainingProgramTimeState"}
On OH2 I have created a dummy Item.
When I set values via the OH3 console it works.
But then the washer is active, the new values from OH3 do not get send to OH2.
OH3 log:
2023-04-30 22:30:22.328 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Waschmaschine_K_RemainingProgramTimeState' changed from 120 s to 60 s
My guess is that the valued are not set by a commandby the Home Connect binding.
But the remote binding only sends updates when the Item receives a command. Right?
It transfers any item command from the local server to the remote server
I tried to workaround this by using a proxy Item in OH3 and send a command for every update.
Number:Time remoteWaschmaschine_K_RemainingProgramTimeState "Remaining program time [JS(clockfmt.js):%s]" {channel="remoteopenhab:server:oh2:Waschmaschine_K_RemainingProgramTimeState"}
rule "Waschmaschine_K_RemainingProgramTimeState Update"
Item Waschmaschine_K_RemainingProgramTimeState changed
remoteWaschmaschine_K_RemainingProgramTimeState.sendCommand(Waschmaschine_K_RemainingProgramTimeState)
But now I got another problem:
2023-04-30 22:31:07.146 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'remoteopenhab-1' failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.ac
tions.BusEvent.sendCommand(org.openhab.core.items.Item,java.lang.String) on instance: null in remoteopenhab
What am I doing wrong?
