I’ve put some time in setting up an OpenHAB3 instance with Remoteopenhab and finally also solved the status changes, etc. Now I have one problem left: I cannot propagate the state of a door or window contact. On my OpenHAB3 instance the definition looks like this:
Contact DOOR_UG_Flur "Door/Window [%s]" { channel="zwave:aeon_dsb29_00_000:controller:doorSensor2:sensor_door", channel="remoteopenhab:server:myserver:DOOR_UG_Flur"[profile="system:follow"] }
and on the remote myserver (OpenHAB2) it’s
Contact DOOR_UG_Flur "Zwischentür Keller [MAP(de.map):%s]" <frontdoor>
Now - when I open/close the door, the contact recognizes that and on the OpenHAB3 instance I get the correct state. Remoteopenhab also seems to try to propagate the state but on the OpenHAB2 server I get then
[WARN ] [rest.core.internal.item.ItemResource] - Received HTTP POST request at 'items/DOOR_UG_Eingang' with an invalid status value 'CLOSED'.
and I’m stuck there. I tried a bit of searching for this but didn’t find a solution other than saying “you cannot post the state over to a Contact” which is a bit unsatisfying. I assume that the makers of Remoteopenhab have thought of this and I’m just not aware of the proper configuration, so perhaps somebody has an idea of how to get the Contact state properly reflected on the OpenHAB2 instance?
Thanks a lot for any help.
