I want to remove HomeKit from oh2 and I have done so i paperui. I have cleared pairing but my log files are filled with error that seems too be related to HomeKit. What can I do too get rid of all the errors. Openhab.log is filled with this errors
2018-04-02 15:40:24.090 [INFO ] [org.openhab.io.homekit ] - FrameworkEvent INFO - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /var/lib/openhab2/cache/org.eclipse.osgi/232/0/.cp/lib/org.glassfish.javax.json-1.0.4.jar
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:321) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.basicOpen(ZipBundleFile.java:93) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:106) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.checkedOpen(ZipBundleFile.java:65) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getEntry(ZipBundleFile.java:240) ~[?:?]
at org.eclipse.osgi.storage.bundlefile.BundleFile.getResourceURL(BundleFile.java:136) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findResourceImpl(ClasspathManager.java:418) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalResources(ClasspathManager.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalResources(ModuleClassLoader.java:321) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalResources(BundleLoader.java:837) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findResources(BundleLoader.java:693) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.getResources(ModuleClassLoader.java:231) ~[?:?]
at org.eclipse.osgi.internal.framework.ContextFinder.getResources(ContextFinder.java:165) ~[?:?]
at java.util.ServiceLoader$LazyIterator.hasNextService(ServiceLoader.java:348) ~[?:?]
at java.util.ServiceLoader$LazyIterator.hasNext(ServiceLoader.java:393) ~[?:?]
at java.util.ServiceLoader$1.hasNext(ServiceLoader.java:474) ~[?:?]
at javax.json.spi.JsonProvider.provider(JsonProvider.java:89) ~[?:?]
at javax.json.Json.createWriter(Json.java:198) ~[?:?]
at com.beowulfe.hap.impl.json.EventController.getMessage(EventController.java:27) ~[?:?]
at com.beowulfe.hap.impl.connections.SubscriptionManager.publish(SubscriptionManager.java:83) ~[?:?]
at com.beowulfe.hap.impl.connections.SubscriptionManager.lambda$addSubscription$30(SubscriptionManager.java:31) ~[?:?]
at org.openhab.io.homekit.internal.HomekitAccessoryUpdater.lambda$2(HomekitAccessoryUpdater.java:53) ~[?:?]
at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:234) [109:org.eclipse.smarthome.core:0.10.0.b1]
Caused by: java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/232/0/.cp/lib/org.glassfish.javax.json-1.0.4.jar (Filen eller katalogen finns inte)
at java.util.zip.ZipFile.open(Native Method) ~[?:?]
at java.util.zip.ZipFile.<init>(ZipFile.java:225) ~[?:?]
at java.util.zip.ZipFile.<init>(ZipFile.java:155) ~[?:?]
at java.util.zip.ZipFile.<init>(ZipFile.java:169) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:304) ~[?:?]
... 25 more
2018-04-02 15:40:24.092 [INFO ] [org.openhab.io.homekit ] - FrameworkEvent INFO - org.openhab.io.homekit
java.io.IOException: Exception in opening zip file: /var/lib/openhab2/cache/org.eclipse.osgi/232/0/.cp/lib/org.zeromq.curve25519-java-0.1.0.jar
Caused by: java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/232/0/.cp/lib/org.zeromq.curve25519-java-0.1.0.jar (Filen eller katalogen finns inte)
... 25 more
Ok, I have tried that. Now I get the following error (Im sorry I am not able too understand the errors, my programming skills aren’t good enugh) Is it possible that this error is caused because all bindings were removed when I cleared the cache?
2018-04-03 20:25:31.843 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2018-04-03T20:25:31.826+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
logInfo(<XStringLiteralImpl>,<XStringLiteralImpl>)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@4a1cc5bb
} ] threw an unhandled Exception:
java.lang.reflect.UndeclaredThrowableException: null
at com.sun.proxy.$Proxy152.apply(Unknown Source) [?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) [145:org.eclipse.smarthome.model.script:0.10.0.b1]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
Caused by: org.eclipse.smarthome.model.script.engine.ScriptExecutionException: Could not cast NULL to org.eclipse.smarthome.core.library.types.DateTimeType; line 7, column 26, length 32
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter._doEvaluate(ScriptInterpreter.java:232) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:233) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:759) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:219) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1115) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1045) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:763) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:871) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:225) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:457) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
... 4 more
2018-04-03 20:25:31.864 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2018-04-03T20:25:31.826+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [115:org.eclipse.smarthome.core.scheduler:0.10.0.b1]
Caused by: java.lang.reflect.UndeclaredThrowableException
at com.sun.proxy.$Proxy152.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
... 1 more
