Hi, I had created 1 items files for both my shclage locks which are for seperate appartments they were configured in a group called gLock. Which I didn’t realize at first was bad. So I created seperate files for either lock and removed the group information. For some reason the locks are still linked. When I send a signal to the first one it updates the second one and vice versa.
Sometimes you need to clear your cache and temp files after making a rule change or give it long enough it will start acting right. In your case, with locks, you probably need the change sooner than later.
If your using openhabian you can use the following command.
sudo service openhab2 stop && sudo rm -rf /var/lib/openhab2/cache/* && sudo rm -rf /var/lib/openhab2/tmp/* && sudo reboot
Or do it manually, just don’t delete the actual cache and temp file, only what’s inside the file.
Thanks for this, I’ll test it later, when my tenants are not around
What’s the fun in that !!
Hehey your right, lets say I had a lot of fun last night without realizing it.
