Hi all, just tried the binding today and bumped into an error message:
cookie value not found!
Checked the login crendentials because of the log, they appear to be ok.
Any suggestions? Many thanks in advance!
OpenHab 4.2.1 on a Pi
17:19:48.657 [WARN ] [ult.internal.api.MyRenaultHttpSession] - Login Error: cookie value not found! Response: {
"callId": "89021a215c48449fb8b63da7d541909e",
"errorCode": 403042,
"errorDetails": "invalid loginID or password",
"errorMessage": "Invalid LoginID",
"apiVersion": 2,
"statusCode": 403,
"statusReason": "Forbidden",
"time": "2024-09-15T15:19:48.639Z"
17:19:48.660 [WARN ] [nault.internal.handler.RenaultHandler] - Error My Renault Http Session.
org.openhab.binding.renault.internal.api.exceptions.RenaultException: Login Error: cookie value not found in JSON response
at org.openhab.binding.renault.internal.api.MyRenaultHttpSession.login(MyRenaultHttpSession.java:116) ~[?:?]
at org.openhab.binding.renault.internal.api.MyRenaultHttpSession.initSesssion(MyRenaultHttpSession.java:78) ~[?:?]
at org.openhab.binding.renault.internal.handler.RenaultHandler.getStatus(RenaultHandler.java:252) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
at java.lang.Thread.run(Thread.java:833) [?:?]
17:19:48.669 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'renault:car:ZOE9a811f5aad' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Login Error: cookie value not found in JSON response
17:19:49.015 [WARN ] [nault.internal.handler.RenaultHandler] - Disabling unsupported HVAC status update.
17:19:49.079 [WARN ] [nault.internal.handler.RenaultHandler] - Disabling unsupported cockpit status update.
17:19:49.128 [WARN ] [nault.internal.handler.RenaultHandler] - Disabling unsupported location update.
17:19:49.193 [WARN ] [nault.internal.handler.RenaultHandler] - Disabling unsupported battery update.
17:19:49.261 [WARN ] [nault.internal.handler.RenaultHandler] - Disabling unsupported lock status update.
