- Platform information:
- Hardware: Synology NAS intel CPU
- OS: Linux (Synology DSM 6) in docker
- Java Runtime Environment: ?
- openHAB version: 4
- Issue of the topic:
Hello Community,
I’m was running a quite large openhab 1 system for more than 10 years.
Last December I migrated to openhab4 with a lot of blood, sweat and tears ![]()
Most is running. As the last step I installed the certificate exported from the Synology NAS to have https access to the wedbsite. It workted fine until I had to renew it.
To install, the first time, I run these steps at the NAS:
docker cp /root/cert/cert.pem openhab4:/openhab/userdata/etc/cert.pem
docker cp /root/cert/privkey.pem openhab4:/openhab/userdata/etc/privkey.pem
docker cp /root/cert/chain.pem openhab4:/openhab/userdata/etc/chain.pem
and then in openhab :
cat cert.pem chain.pem > fullchain.pem
openssl x509 -in fullchain.pem -text -noout
keytool -import -alias openhab-cert -keystore keystore -file cert.pem
keytool -import -trustcacerts -alias openhab-chain -keystore keystore -file chain.pem
openssl pkcs12 -export -in cert.pem -inkey privkey.pem -certfile chain.pem -out openhab.p12 -name openhab
keytool -importkeystore -srckeystore openhab.p12 -srcstoretype PKCS12 -destkeystore keystore -deststoretype JKS
Now I copied the new pem’s and tried to run the same steps.
But now I have to enter a password to the keystore in command :
I can’t remember that I set a password at the first time ![]()
How can I get access to the “old” keystore to steup a new certificate?
Thanks in advance,
Ralf.
