I’m trying to add a Reolink TrackMix WiFi to my system running OH 4.1.0. When I enable the thing in OH the cam crashes every couple of minutes.
This is the config of the thing:
UID: ipcamera:reolink:reo_c_01
label: reo-c-01
thingTypeUID: ipcamera:reolink
configuration:
mjpegOptions: -q:v 5 -r 2 -vf scale=640:-2 -update 1
ipAddress: 192.168.178.48
updateImageWhen: "0"
gifPreroll: 0
onvifPort: 8000
ffmpegLocation: /usr/bin/ffmpeg
ipWhitelist: DISABLE
mp4OutOptions: -c:v copy -c:a copy
pollTime: 1000
useToken: false
password: SECRET
port: 80
nvrChannel: 0
snapshotOptions: -an -vsync vfr -q:v 2 -update 1
ptzContinuous: true
onvifMediaProfile: 1
gifOutOptions: -r 2 -filter_complex
scale=-2:360:flags=lanczos,setpts=0.5*PTS,split[o1][o2];[o1]palettegen[p];[o2]fifo[o3];[o3][p]paletteuse
hlsOutOptions: -strict -2 -f lavfi -i aevalsrc=0 -acodec aac -vcodec copy
-hls_flags delete_segments -hls_time 2 -hls_list_size 4
username: openhabian
channels:
- id: startStream
channelTypeUID: ipcamera:startStream
label: Start HLS Stream
description: Lower the delay to start casting the camera by creating the files
non stop in case they are needed.
configuration: {}
- id: pollImage
channelTypeUID: ipcamera:pollImage
label: Poll Image
description: This can be used to trigger snapshot updates when an external PIR,
button or other form of sensor turns this channel ON.
configuration: {}
- id: image
channelTypeUID: ipcamera:image
label: Image
description: Low frame rate image from your camera. Recommend this is NOT used
unless you have large pollTime.
configuration: {}
- id: recordingGif
channelTypeUID: ipcamera:recordingGif
label: GIF Recording
description: Indicates how long the recording will occur for and when the file
is created, the channel will change to 0 by itself.
configuration: {}
- id: gifHistory
channelTypeUID: ipcamera:gifHistory
label: GIF History
description: A history of the last GIFs created in a CSV formatted string.
configuration: {}
- id: gifHistoryLength
channelTypeUID: ipcamera:gifHistoryLength
label: GIF History Length
description: How many GIFs are stored in the history.
configuration: {}
- id: recordingMp4
channelTypeUID: ipcamera:recordingMp4
label: MP4 Recording
configuration: {}
- id: mp4History
channelTypeUID: ipcamera:mp4History
label: MP4 History
description: A history of the last mp4 recordings created in a CSV formatted string.
configuration: {}
- id: mp4HistoryLength
channelTypeUID: ipcamera:mp4HistoryLength
label: MP4 History Length
description: How many mp4 recordings are stored in the history.
configuration: {}
- id: lastMotionType
channelTypeUID: ipcamera:lastMotionType
label: Last Motion Type
description: A string that contains the type of motion alarm that was last triggered.
configuration: {}
- id: lastEventData
channelTypeUID: ipcamera:lastEventData
label: Last Event Data
description: A string that contains detailed data on the last alarm that was triggered.
configuration: {}
- id: ffmpegMotionControl
channelTypeUID: ipcamera:ffmpegMotionControl
label: Control FFmpeg Motion Alarm
description: Enable/Disable the motion alarm and control the sensitivity.
configuration: {}
- id: ffmpegMotionAlarm
channelTypeUID: ipcamera:ffmpegMotionAlarm
label: FFmpeg Motion Alarm
description: FFmpeg has detected motion.
configuration: {}
- id: enableMotionAlarm
channelTypeUID: ipcamera:enableMotionAlarm
label: Enable Motion Alarm
description: By using this feature you can stop the camera from sending e-mails
when you are actually home.
configuration: {}
- id: motionAlarm
channelTypeUID: ipcamera:motionAlarm
label: Motion Alarm
description: Motion has been detected.
configuration: {}
- id: cellMotionAlarm
channelTypeUID: ipcamera:cellMotionAlarm
label: Cell Motion Alarm
description: Cell based motion has been detected.
configuration: {}
- id: externalMotion
channelTypeUID: ipcamera:externalMotion
label: External Motion
description: Use any external sensor like a ZWave PIR sensor to flag that the
camera has motion in its field of view.
configuration: {}
- id: enableAudioAlarm
channelTypeUID: ipcamera:enableAudioAlarm
label: Enable Audio Alarm
when you are having a party.
configuration: {}
- id: thresholdAudioAlarm
channelTypeUID: ipcamera:thresholdAudioAlarm
label: Audio Alarm Threshold
description: By moving this control you should be able to change how sensitive
the audio alarm is to soft or loud noises.
configuration: {}
- id: audioAlarm
channelTypeUID: ipcamera:audioAlarm
label: Audio Alarm
description: Audio has triggered an Alarm.
configuration: {}
- id: pan
channelTypeUID: ipcamera:pan
label: Pan
description: Pan the camera to a new position.
configuration: {}
- id: tilt
channelTypeUID: ipcamera:tilt
label: Tilt
description: Tilt the camera to a new position.
configuration: {}
- id: zoom
channelTypeUID: ipcamera:zoom
label: Zoom
description: Zoom the camera to a new value.
configuration: {}
- id: gotoPreset
channelTypeUID: ipcamera:gotoPreset
label: Go To Preset
description: Move a P.T.Z camera to this ONVIF preset location.
configuration: {}
- id: mjpegUrl
channelTypeUID: ipcamera:mjpegUrl
label: MJPEG URL
description: A link you can use in openHAB/HABpanel to fetch a MJPEG video feed
from the camera.
configuration: {}
- id: rtspUrl
channelTypeUID: ipcamera:rtspUrl
label: RTSP URL
description: A link that the camera uses for RTSP.
configuration: {}
- id: imageUrl
channelTypeUID: ipcamera:imageUrl
label: Image URL
description: A link you can use to fetch a static image from the camera.
configuration: {}
- id: hlsUrl
channelTypeUID: ipcamera:hlsUrl
label: HLS URL
description: A link you can use in openHAB to cast video feeds.
configuration: {}
- id: carAlarm
channelTypeUID: ipcamera:carAlarm
label: Car Alarm
description: A car has triggered the Vehicle Detection.
configuration: {}
- id: humanAlarm
channelTypeUID: ipcamera:humanAlarm
label: Human Alarm
description: A person has triggered the Human Detection.
configuration: {}
- id: animalAlarm
channelTypeUID: ipcamera:animalAlarm
label: Animal Alarm
description: An animal has triggered the object detection.
configuration: {}
- id: faceDetected
channelTypeUID: ipcamera:faceDetected
label: Face Detected Alarm
description: A face has been detected.
configuration: {}
- id: autoLED
channelTypeUID: ipcamera:autoLED
label: Auto LED
description: Turn the automatic mode for the LED ON and OFF.
configuration: {}
- id: enableLED
channelTypeUID: ipcamera:enableLED
label: LED Controls
description: Turn the LED ON and OFF and if supported also 0-100% dimming.
configuration: {}
- id: textOverlay
channelTypeUID: ipcamera:textOverlay
label: Text Overlay
description: Enter some text you wish to overlay on top of the cameras snapshot
and video streams.
configuration: {}
- id: activateAlarmOutput
channelTypeUID: ipcamera:activateAlarmOutput
label: Alarm Output 1 ON/OFF
description: You can use the cameras output to trigger a device like a burglar alarm.
configuration: {}
- id: doorBell
channelTypeUID: ipcamera:doorBell
label: Door Bell
description: The button has been pushed.
configuration: {}
- id: enableRecordings
channelTypeUID: ipcamera:enableRecordings
label: Enable Recordings
description: Enable/Disable the cameras internal recordings
configuration: {}
- id: enableFTP
channelTypeUID: ipcamera:enableFTP
label: Enable FTP
description: Turn the FTP features of the camera on and off
configuration: {}
Log filtered for ‘onvif’ startup till crash and ‘ipcam’:
(log deleted)
Any suggestions on what to do/try next are very welcome. The cam itself does a very good job, but it shouldn’t be crashing of course - which is the case until I activate the oh-thing.
